ICEM: Delete curves prior to meshing?
Like Tree1Likes
  • 1 Post By myron
Old   April 7, 2008, 12:44
Default ICEM: Delete curves prior to meshing?
joerg
Hello all, I have a rather simple question: Do I want to remove curves from my geometry before meshing the volume with tetras? Regards, joerg.
Old   April 7, 2008, 17:36
Default Re: ICEM: Delete curves prior to meshing?
J
I don't think so...especially if the curve defines an edge of a boundary...eg the circle around an inlet...I am working with aneurysms and I need this curve to obtain a good mesh... But I am not a specialist in ICEM...mine is just an idea
J
Old   April 8, 2008, 05:41
Subha
Hai Jeorg,
Right click on the premesh and you would see that the project surfaces is turned on. So the mesh depends on the surfaces of your model and you don't have to delete your curves But if you delete the curves which are associated then you would probably won't be getting the right mesh.
With Regards,
Subha.
Old   April 8, 2008, 11:43
myron
The tetra mesher uses geometry curves and points to capture 'hard' features of geometry (sharp edges, corners, etc.). The mesher associates nodes on the mesh to these geometry features. Thus, you want to preserve curves and points that define hard edges and corners if you want that detail kept in the mesh. Curves and points in areas that don't 'matter' (smooth connections between surfaces, etc) should be deleted.
granzer likes this.
Old   April 8, 2008, 11:48
Default Thanks alot! This answers my question! *nt*
joerg
no text here
problem with surface creation in ICEM from multiple curves dialolema ANSYS Meshing & Geometry 2 October 27, 2014 14:14
[ICEM] complex 2D meshing on ICEM kassab ANSYS Meshing & Geometry 26 April 14, 2014 22:02
[ICEM] ICEM meshing problem xyq102296 ANSYS Meshing & Geometry 6 October 28, 2010 11:09
