CEL expression for setting high temperature at a coordinate/ surface at time, t=10s
Like Tree1Likes
  • 1 Post By ghorrocks
Old   May 3, 2024, 08:06
Post CEL expression for setting high temperature at a coordinate/ surface at time, t=10s
Bishwajit Nandi
bishwajitdgp is on a distinguished road
Hi
I want to simulate a combustion reaction in Ansys CFX. I am defined methane combustion (single-step) reaction.
I want to initialize a high temperature source in my geometry at time let say, t =10 s (I am performing a transient state analysis) so that my combustion reaction starts.
Please help me how to define an expression for initialization.
Thank you in advance
bishwajitdgp is offline   Reply With Quote
Old   May 4, 2024, 04:32
Have you done the CFX combustion tutorials? Make sure you have done any relevant tutorials so you know how to set it up.
But to answer your direct question - you can apply a heat source on a boundary or a volume.
Boundaries are easy - just define a heat flux boundary (or maybe temperature if you want). No need for source terms.
Volumes will require a source term. If the heat is just a constant heating rate (or heat flux) then you can use this directly in the source term. If you want to source to go to a defined temperature you will need to do a source term of the form -c(T-T(defined)). Let us know if you want us toe explain this further - and it is discussed in the documentation under source terms.
Opaque likes this.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
ansys cfx 2021 r2, combustion gas, explosions, reaction, temperature equation
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 03:36
laplacianFoam with source term Herwig OpenFOAM Running, Solving & CFD 17 November 19, 2019 14:47
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 01:01
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
