March 7, 2024, 10:47 |
Solver stalled with Spalart-Allmaras model
Rep Power: 2 |
I have a 1-stage compressor model consisting of a rotor and stator. I have already analyzed it with the SST turbulence model. The y+ for both domains is about ~1. I was trying to test the Spalart-Allmaras model which is still a beta feature in CFX. But when it started in the solver, the solver just stopped and did not move forward from "Initial Conditions Supplied by Fields in the Input Files". Even when I clicked the stop button to kill it, it did not respond.
I tested with default and scalable wall function, but nothing changed. The version of Ansys is 2021 R2. Below is where it stopped: Code:
+--------------------------------------------------------------------+ | Initial Conditions Supplied by Fields in the Input Files | +--------------------------------------------------------------------+ Domain Name : Rotor Courant Number Density Density Derivative wrt Pressure at Constant Temperature Dynamic Viscosity Eddy Viscosity Isothermal Compressibility Pressure Rotational Energy Rothalpy Shock Indicator Specific Heat Capacity at Constant Pressure Static Enthalpy Static Entropy Temperature Thermal Conductivity Total Enthalpy Turbulence Kinetic Energy Velocity Wall Scale Domain Name : Stator Absolute Pressure Courant Number Density Density Derivative wrt Pressure at Constant Temperature Density.Beta Density.Gradient Dynamic Viscosity Eddy Viscosity Isothermal Compressibility Local Speed of Sound Mach Number Pressure Pressure.Beta Pressure.Gradient Real Partition Number Rotation Velocity Shear Strain Rate Shock Indicator Specific Heat Capacity at Constant Pressure Specific Heat Capacity at Constant Volume Specific Volume Static Enthalpy Static Entropy Temperature Thermal Conductivity Total Density Total Enthalpy Total Enthalpy.Gradient Total Pressure Total Temperature Turbulence Kinetic Energy Velocity Velocity.Beta Velocity.Curl Velocity.Gradient Vorticity Wall Distance Wall Scale Wall Scale.Gradient |
March 7, 2024, 11:24 |
Rep Power: 33 |
If you are running in parallel, likely a defect where the simulation is "locked".
You can try running it in serial, and see if it passes that point. You decide how to run after that.
March 7, 2024, 11:31 |
Rep Power: 2 |
Thank you Opaque. So it runs in serial mode. What was the issue here then? Should I use a serial mode to use SA mode? I have never seen this type of issue over the last 10 years with Ansys though.
March 7, 2024, 13:02 |
Rep Power: 33 |
Spalart-Allmaras has been beta for a while. Likely not fully tested for all configurations by Ansys 2021R2.
Do you have access to Ansys 2024R1, or 2023R2? Possible someone else already reported problem
March 7, 2024, 13:40 |
#5 | |
Rep Power: 2 |
Update: I looked at the Ansys Help manual and it looks like it is a beta feature still in 2024 R1. There is no manual for the SA model in CFX. |
March 7, 2024, 14:49 |
Rep Power: 33 |
I think you are correct, still beta, but I would try it out in case it is now working.
beta feature, cfx, spalart-allmaras, turbulence model |
Accurate Physical meaning of 'Blocking wall effect' of Spalart Allmaras model | FluidKo | Main CFD Forum | 1 | March 23, 2022 02:28 |
Spalart Allmaras Gamma Re Theta Model | taxalian | SU2 | 4 | December 14, 2020 05:45 |
Spalart Allmaras Turbulence Model: Compressible | hasini | Main CFD Forum | 1 | October 7, 2020 07:03 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 15:32 |
nut wall function for Spalart Allmaras model | wei_wu | OpenFOAM Programming & Development | 0 | February 9, 2010 17:30 |
