Inflation layer addition causes divergence CFX |
February 26, 2024, 08:14 |
Johan M
Rep Power: 5 |
Hi Everyone,
I have encountered divergence in CFX pump simulation involving a volute and impeller. Both geometries were automatically generated within Ansys Vista Centrifugal Pump (CPD). Problem area: The entrance of the volute consists of an InletHub, InletShroud and Inlet. InletHub and InletShroud are the lower and upper walled regions of the volute seen selected in image 0. Inlet is the fluid entrace of the volute, which would be interfaced to the exit of the impeller with a mixing plane interface. The volute was meshing using Ansys meshing. The scoping method using automatic meshing did not include regions marked in image 1 which are the InletHub and InletShroud walls. Without inflation layers on them, the solution converges. However when I manually insert inflation layers, the solution diverges with spiked residuals and unrealistic total outlet pressure monitors seen in image 1,2. The mesh quality in both cases are within the failure criteria prescribed in the manual. Current workaround: Since the addition of inflation layers on the wall was the issue, i adjusted the volute geometry until it only included the Inlet at the entrance - the InletHub and InletShroud were reduced to zero. I am also doing a simulation where I mesh the volute with Fluent Meshing with Hexcore cells to check if I achieve a better solution. This sim is with the InletHub, InletShroud and Inlet configuration. I would like to know what might cause the insertion of inflation layers to result in such a drastic divergence. Additionally, I would appreciate any other advice on a better workaround that doesn't involve such a drastic geometry change in the volute. Kind regards, Johan |
February 26, 2024, 10:59 |
Rep Power: 33 |
Mesh affects accuracy; however, a finer mesh may require a smaller timescale for the model to converge.
If a coarse mesh model, and coarse does not mean small mesh count, converges for a given timescale, it does not mean the finer mesh will converge for the same timescale. Have you tried reducing your timescale? The above assumes your inflation layer is "correct". That is, there is nothing wrong with the mesh.
February 26, 2024, 18:04 |
Rep Power: 144 |
I would check the points covered in this FAQ before proceeding: https://www.cfd-online.com/Wiki/Ansy...gence_criteria
February 27, 2024, 14:14 |
Daniel
Rep Power: 9 |
Can you share an image of your mesh?
March 2, 2024, 12:03 |
#5 | |
Johan M
Rep Power: 5 |
March 2, 2024, 12:08 |
#6 | |
Johan M
Rep Power: 5 |
March 2, 2024, 12:09 |
Johan M
Rep Power: 5 |
cfx, divergence, pump mesh, volute |
[snappyHexMesh] No generation of layer onto zerothickness surface | crubio.abujas | OpenFOAM Meshing & Mesh Conversion | 3 | October 25, 2022 04:20 |
[snappyHexMesh] Error defining boundary layer around cube snappyHexMesh | crizpi21 | OpenFOAM Meshing & Mesh Conversion | 5 | October 16, 2021 11:56 |
[snappyHexMesh] Prism layer collapsing in refinement transition | rubenparedes | OpenFOAM Meshing & Mesh Conversion | 8 | May 13, 2021 11:55 |
[ANSYS Meshing] Inflation layer or not? | FCTCD | ANSYS Meshing & Geometry | 0 | June 20, 2018 09:47 |
Struggling to create inflation layer around 3D aerofoil in Ansys (CFX) | duncan1098 | ANSYS | 0 | February 1, 2018 09:21 |
