Mesh stifness devided by zero
Like Tree1Likes
  • 1 Post By Gert-Jan
Old   February 18, 2024, 04:13
Default Mesh stifness devided by zero
Amin
maba is on a distinguished road
Hello everyone,
I am simulating a heaving plate using dynamic mesh. As the amplitude of oscillation is high, I wanted to use varying stiffness (1 [m^3 s^-1]/Wall Distance) to preserve the mesh near the wall where the mesh is fine. However, when the run starts, it gives the following error:
"PROBLEM ENCOUNTERED WHEN EXECUTING CFX EXPRESSION LANGUAGE
| The CFX expression language was evaluating:
| Mesh Stiffness
| The problem was:
| DIVIDE-BY-ZERO
Does anyone know what the problem is?
maba is offline   Reply With Quote
Old   February 18, 2024, 08:53
Gert-Jan
Gert-Jan will become famous soon enough
The message shows that CFX is dividing by zero. So, somewhere the variable Wall Distance equals 0. Quite obvious, not?
You could prevent the division by zero by maximizing the denominator like: 1 [m^3 s^-1]/max(1e-6[m],Wall Distance)
Then CFX won't divide by 0, but by 1e-6[m] if Wall Distance is smaller than 1e-6. Not sure if 1e-6 is okay for your application. That is what you should test.
Opaque likes this.
Gert-Jan is offline   Reply With Quote
cfx, dynamic mesh, varying stiffness
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
[snappyHexMesh] High quality mesh for wind in complex urban environment ziboaa OpenFOAM Meshing & Mesh Conversion 1 January 12, 2021 16:33
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[ICEM] Bad Quality Hybrid Mesh External Flow tim13 ANSYS Meshing & Geometry 0 March 8, 2020 03:22
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
