Particle Tracking - Expression for Coefficient of Restitution
Like Tree2Likes
  • 2 Post By ghorrocks
Old   February 2, 2024, 06:58
Default Particle Tracking - Expression for Coefficient of Restitution
PatLe is on a distinguished road
Hello together,
I'm doing a particle tracking in a turbo machinery and I'm mostly interested in the particle behavior at the blades. I'm assuming, that the particles bounce of the walls, so I set a value for the perpendicular and parallel coefficient of restitution. In experiments at my university we saw, that it is to easy to assume a constant value for the coefficients of restitution. So my idea is to create an expression, which depends on the particle velocity directly before the impact and the wall impact angle of the particle.
-> Perpendicular CoR = f(Particle.Velocity, Wall Impact Angle)
-> Parallel CoR = f(Particle.Velocity, Wall Impact Angle)
I already tried to implement the expressions, but there were some problems.
The particle velocity is a non-scalar variable, which is not allowed to put in the coefficient of restitution. I also tried to create my own velocity variable ( -> Particle.Vel = sqrt(Particle.Velocity u^2 + Particle.Velocity v^2 + Particle.Velocity w^2) ) but there is another error message, that this is a field valued variable and the coefficient of restitution only allows single valued parameters.
Do you know how to fix that problem?
Another problem is, that I don't find a variable for the wall impact angle, that I can call in the expression. Do you know, if there is a variable I can call?
I already read in other threads, that this should be possible, but I never saw an solution that worked.
Thank you very much for your help!
PatLe is offline   Reply With Quote
Old   February 2, 2024, 19:21
I don't think you can do this in CEL. I think you will need to do it with user fortran. Have a look in the documentation for the user fortran routines for particle tracking.
Opaque and PatLe like this.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
particle tracking
Particle tracking file per time step in an Unsteady Particle Tracking Manu4CFD FLUENT 1 December 29, 2022 08:15
Particle tracking prob, urgent. sakurabogoda CFX 1 March 11, 2013 22:11
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 19:44
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 07:25
restarting lagrange (particle tracking) simulation dbdias CFX 0 September 22, 2007 20:26
