How to apply angle of attack on a 2D axisymmetric body?
Like Tree1Likes
  • 1 Post By ghorrocks
Old   January 29, 2024, 13:04
Default How to apply angle of attack on a 2D axisymmetric body?
funnier is on a distinguished road
I’m doing cfd simulation of rocket on Ansys cfx, the geometry of rocket is 2D axisymmetric. How can I apply angle of attack on rocket?
funnier is offline   Reply With Quote
Old   January 29, 2024, 17:12
I presume the rocket is long and cylindrical, possibly with a conical nose. And by angle of attack you mean the rocket is not travelling in the direction of its axis, it is slightly off.
In this case the simulation is not a 2D axisymmetric model any more. You can going to have to use the full 3D geometry. You may be able to use a symmetry plane depending on what wake structures you expect to see (some wake structures are non-symmetric, so you would need a full 3D model with no symmetry plane to capture these).
Opaque likes this.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
ghorrocks is online now   Reply With Quote
Old   January 29, 2024, 18:11
I uploaded picture of the rocket. Can you please look at it?
Old   January 29, 2024, 18:29
As I said, you are going to have to generate a full 3D model of this. So take your 2D slice and rotate it around to generate a 3D body. Then do a rotation on the body it to generate the angle of attack you want.
You will then have to remesh and run the simulation again as a full3D model. It will take a lot longer to run, of course, as the mesh will be much larger.
angle of attack, axisymetrical, axisymmetric, axisymmetric 2d cfx, cfx & fluent
Calculating Oscillating Aerofoil Angle of Attack MechEng86 FLUENT 1 August 20, 2019 09:19
Angle of Attack simulations redordead FLUENT 2 June 15, 2016 04:50
how to plot attack angle along with impeller span direction at leading edge wildli FLUENT 0 August 31, 2010 15:47
convegence problem with high angle of attack littlelz CFX 2 October 28, 2009 07:07
Proper output of angle of attack in CFX post Kevin CFX 3 October 18, 2006 13:18
