Defining an additional variable in CFX
Like Tree2Likes
  • 1 Post By ghorrocks
Old   December 10, 2023, 07:53
Default Defining an additional variable in CFX
Xavier
shearThickening is on a distinguished road
Hello everyone,
My problem originates from calculating the Nusselt number for heat transfer of the flow in a circular pipe with uniform wall heat flux. The theoretical value is different from that calculated with Nu=\frac{q D}{(Tw-Tbulk)k}.
I'm following a solution suggested in:
Convective heat transfer issues in CFX
by defining an additional variable for Tw. For some reason, which I don't know, I can't just calculate the area-average for temperature at the wall. He provide a code for Tw as
LIBRARY:
  ADDITIONAL VARIABLE: Tw
    Boundary Only Field = On
    Option = Definition
    Tensor Type = SCALAR
    Units = [K]
    Variable Type = Unspecified
  END
END
FLOW: Flow Analysis 1
  DOMAIN: HeXe
    FLUID MODELS:
        Additional Variable Value = T
        Option = Algebraic Equation
      END
    END
  END
END
I'm not sure how to use this code in CFX. Will appreciate any help.
shearThickening is offline   Reply With Quote
Old   December 10, 2023, 17:21
The starting point for a calculation like this is to use areaAve(T)@Wall for the wall temperature, whatever your defined bulk temperature is for Tbulk, and the other properties as evaluated at the wall.
The thread you link to goes into a lot more detail on this and discusses things to consider to get much better accuracy. But only look at this more complex stuff if the basic stuff I just described is inadequate.
So before you look at the complex solution discussed in that thread, have you looked at a basic Nusselt number calculation? What does that say?
shearThickening likes this.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   December 12, 2023, 07:25
Xavier
Thanks ghorrocks for your response and sorry for the late reply. In fact, yes I'm looking for better accuracy if possible because the error is about 10% for this simple case. If the mentioned solution wouldn't reduce my error, I will accept what I am getting. But for the sake of knowledge, how can I implement this code? As a mathematician, I don't have much experience with CFD software but I had to work with it because implementing a numerical technique for a turbulent model from scratch is a waste of time.
Old   December 12, 2023, 18:03
The text snippet is CFX command language, CCL. In CFX-Pre you can edit the CCL directly and add the snippet into the CCL of your run.
Note that as you refine the mesh the error of the simple areaAve(T)@Wall should also reduce. So if you have refined your mesh enough to give an accurate simulation then the simple wall temeprature approach might be good enough.
cfx, nusselt number, temperature bc
How to set bounds for additional variables NatpJ CFX 14 August 23, 2023 19:34
Diffusivity coefficient dependent on the additional variable 831726 CFX 9 June 25, 2018 08:25
How to define a static aditional variable in CFX cardioCFD CFX 8 January 22, 2018 05:58
Negative value of additional variable fkzstar CFX 12 July 9, 2012 19:49
Additional variable John CFX 2 October 16, 2008 06:33
