How to insert the new material (PCM - Water and Ice) into CFX-PRE
Like Tree1Likes
  • 1 Post By ghorrocks
Old   October 30, 2023, 12:32
Default How to insert the new material (PCM - Water and Ice) into CFX-PRE
Kin Feng
wongkinfeng is on a distinguished road
How to insert the new material (PCM—Water and Ice) into CFX-PRE
PCM with a two-component model, as shown in the figure below
wongkinfeng is offline   Reply With Quote
Old   October 30, 2023, 18:30
What are you trying to do? How do the water and ice interact? Is the ice particles in the water? Or is it a water/ice slush? Is there phase change?
Note that CFX does not have a solidification or melting model.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   October 31, 2023, 05:57
Kin Feng
I'm doing a simulation of a thermal energy storage tank. Screenshot 2023-10-31 175424.jpg
The spring-shaped tube is Heat transfer fluid (Air)
The cylindrical tank is PCM (Water)
I need to simulate melting and freezing processes, so I need to add a material for PCM.
Old   October 31, 2023, 06:02
Either you are going to have to develop the solidification model yourself (that is not simple) or switch to another software which does support it.
Old   October 31, 2023, 08:43
Kin Feng
My project must use CFX, so I came here to find the solution. Anyway Thanks your suggestion
Old   November 2, 2023, 18:34
falsc233 is on a distinguished road
hi Glenn, i've seen people implementing the enthalpy-porosity method for melting/solidification problems in CFX by defining a binary mixture of liquid and solid, where the specific heat for each material (phase) is specified to account for the latent heat. A momentum source based on liquid fraction is then applied to dampen fluid motion so that there's no motion in the solid region. Is this type of approach what you mean when you say "develop the solidification model yourself"? Or were you referring to something more fundamental than this? Thank you!
falsc233 is offline   Reply With Quote
Old   November 2, 2023, 18:39
Yes, there are ways of doing it and you have described one - and you can see that there are several features you will have to develop yourself to get it to have the physics you need. You will have to make sure the latent heats are properly handled, the source term is not too strong and not too weak, that is is numerical stable and so on - so you will need a good knowledge of CFD to make it work. If you are confident you can develop this yourself then go for it.
falsc233 likes this.
Multiphase (Air, water and Ice) PropheSor Stein Fluent Multiphase 0 December 7, 2022 09:48
Simulating Ice Accretion in CFX agner583 CFX 3 February 11, 2014 01:50
ice melting simulation pratikmehta ANSYS 3 April 17, 2013 10:52
Ice melting Simulation pratikmehta CFX 13 February 29, 2012 22:14
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
