Rakeshchandra
Rep Power: 5 ![]() |
I'm trying to simulate a butterfly damper opening and closing condition for reference but i'm unable to write a condition such that the damper stops rotating when rotated to 90deg.
Rep Power: 143 ![]() ![]() ![]() ![]() |
There are many ways of doing this:
1) Rotating frame of reference: I suspect this is how you have done it. It is simple and easy to implement and computationally cheap, but you cannot control the rotation beyond a constant velocity. 2) Moving mesh with one domain: This is difficult to implement as the large deformation will make it difficult to deform the mesh and not fold it. I would not recommend this. 3) Moving mesh with two domains: This uses a similar mesh setup to the rotating frame of reference approach, but instead of using a rotating frame of reference to move the butterfly you use moving mesh. This is much more computationally expensive than RFR, but it does give you complete control over the motion. I suspect you will find option 3 as the most viable option.
Rakeshchandra
Thanks for replying, I'm aware of these methods and I was successful to run it but i'm unable to stop rotation. I've provide angular velocity of 0.157 rad/s and I need to stop it's rotation at time of 10sec where the over all simulation is for 45sec. I tried using defining functions to halt it's rotation but wasn't successful. The function that I wrote is:
tt = 45s dt = 0.25 s halt = if(tt >= 5 [s], 0 [radian s^-1], 0.15708 [radian s^-1] IDK where i'm doing wrong. |
#4 | |
Let me repeat:
You have to use option 3 so you can change the angular velocity in a run.
Rakeshchandra
oh thanks for clarifying, I didn't find much references regarding moving the mesh while running could you please share any references of the case.
There are a few tutorial examples which use it, and it is described in the CFX documentation.
ansys 14, cfx & stator & rotor, cfx 15, moving 3d mesh, moving boundary |
How to export time series of variables for one point? | mary mor | OpenFOAM Post-Processing | 8 | July 19, 2017 10:54 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 00:01 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
