sungkue oh
Rep Power: 0 ![]() |
A typical MRF will take an RPM and use a formula like torque_z()@Blade to get a torque or power value.
I want to do the opposite. I want to fix the Torque value to 25 and have the RPM calculated at that time, but I don't know how. What should I do? ![]() |
Rep Power: 144 ![]() ![]() ![]() ![]() |
Sweep a range of RPM values with a series of simulations and you will get a Torque versus RPM curve. Then interpolate on the curve to find the RPM which gives you the torque you want.
#3 | |
sungkue oh
I want the CFX, which is being calculated like a dynamic program, to adjust the RPM to match the power. |
Gert-Jan
Rep Power: 27 ![]() |
This has been asked very often and I have never seen a solution. CFX is not as dynamic as you expect. It has no control mechanism with a feedback loop from generated torque to input RPM. I think mainly since there not easy damping available like in a PID Controller.
Better follow Glenn's approach. Last edited by Gert-Jan; October 24, 2023 at 08:15. |
#5 | |
Rep Power: 33 ![]() |
The tool should be irrelevant to your goal.
mrf, pressure base rpm |
Fatal error | Echidna | CFX | 4 | September 13, 2016 05:50 |
Problem with an old Simulation | FrankW | CFX | 3 | February 8, 2016 04:28 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
Torque Converter Pump Torque = Engine Torque? | Torque_Converter | Main CFD Forum | 4 | November 12, 2012 06:44 |
Fundamental output format control of field values and time | dbxmcf | OpenFOAM | 1 | January 12, 2011 10:50 |
