Error when using non clipped pressure and density |
October 16, 2023, 09:44 |
Steffen
Rep Power: 4 |
I'm trying to use the non-clipped absolute pressure and density for a source term in CFX. Unfortunately, I’m running into errors when I'm implementing this (see the pictures attached). I use an additional variable named pnc, activate it into fluid setup and assign the variable pabsnc (non clipped absolute pressure), but it seems like the variable is not valid. When I use pabs instead, no error is assigned, but pabsnc is called unavailable. (I use Ansys WB R19.2) Maybe someone has a hint. Best regards Steffen Last edited by SteffenBcfd; October 17, 2023 at 04:51. |
October 16, 2023, 17:59 |
Rep Power: 144 |
No images were attached. This FAQ describes how to attach images: https://www.cfd-online.com/Wiki/Ansy...n_the_forum.3F
Please post the CCL of what you are trying to do, or the output file (especially if that reports an error).
October 17, 2023, 04:41 |
Steffen
Rep Power: 4 |
I’m struggling with the cfd online forum servers, most of the time I can’t reach the side due to slow response. When I upload pictures in the post, it’s even worse. By the way, there is not much to say about the issue. When I try to use pabsnc or densitync in a CEL expression or an additional variable I get the error message.
October 17, 2023, 05:10 |
Rep Power: 144 |
You cannot tell much from the screen shots. Please upload your CCL, which is a small text file so easily uploaded. If you do not know how to export CCL it is under File/Export/CCL I think. You can also right click on the tree and choose Command Editor and copy/paste the CCL into a text file.
October 25, 2023, 16:39 |
Steffen
Rep Power: 4 |
Here is the associated CCL File
October 25, 2023, 17:55 |
Rep Power: 144 |
That is a very complex set of CEL expressions and I am not going to be able to debug that for you.
The VARIABLES file says the variable pabsnc is available in CEL. So maybe if you set a CEL expression equal to pabsnc (pabsnc_temp = pabsnc) and then set your additional variable equal to pabsnc_temp it might work.
October 26, 2023, 02:57 |
Steffen
Rep Power: 4 |
If found the error source.
It has nothing to do with the expressions, pabsnc and densitync are only available if you activate the cavitation mass transfer in the fluid pair tab. After this the variables are accessible, looks strange but its working. |
additional variables, cfx 19.2 |
Pressure fields in FOAM, p field, total pressure, etc. | Tobi | OpenFOAM Post-Processing | 9 | March 25, 2022 01:33 |
Wind tunnel Boundary Conditions in Fluent | metmet | FLUENT | 6 | October 30, 2019 12:23 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
