rotate 90 deg in CFX post
Like Tree10Likes
  • 10 Post By CycLone
Old   February 14, 2008, 11:13
Default rotate 90 deg in CFX post
jorn
I have a plane with color according to a variable. When in the 3D viewer of CFX post I right click and choose "predefined camera" -> "towards +X", it always shows the domain 90 degrees of how I want it. Is there a way I can rotate it exactly 90 degrees (other than fiddling with the mouse and trying to get it approximately 90 deg).
Thanks
Old   February 14, 2008, 11:33
Default Re: rotate 90 deg in CFX post
Subha
Hai Jorn,
Goto the Details tab of the Plane and then to view tab in it. Check the apply rotation tab and apply the desired rotaion.
Regards,
Subha.
Old   February 14, 2008, 12:20
jorn
awesome, just what I needed.
Thanks!
Old   February 14, 2008, 12:30
CycLone
This will rotate the plane, not the camera.
To rotate the camera exactly 90 degrees, first align your view with the +/- X axis, then hold the Ctrl key while clicking the up/down arrows on your keyboard.
-CycLone
Old   July 25, 2018, 09:51
Trot
slb@s8 is on a distinguished road
Please explain , how to get the details tab of the plane created in CFX POST? I tried but I am not getting.
Thanks in advance.
slb@s8 is offline   Reply With Quote
Old   September 22, 2023, 06:41
Subba
subba is on a distinguished road
Originally Posted by CycLone
;86095
-CycLone
Hi @CycLone,
if I do so, it is working fine..
If I hold control key and click up/down arrows, camera is rotating bit by bit for each click..
Now I want to reduce the rotation angle for each click.. i.e., for example, it is rotating 10º for every click, now I want to reduce it to 5º to match my necessity angle views.. (just not to jump from 35º to 45º in one click, I want to rotate to 40º from 35º, for example)
How to control this amount of rotation angle for each click? Can we set this angle somewhere in the settings?
Thanks a lot!
subba is offline   Reply With Quote
Old   September 22, 2023, 22:15
I do not think you can control the rotation per click.
If you want fine control over the view angle then I recommend you use a session file or a state file. Then you can edit view angle to get the exact view you want.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   September 23, 2023, 11:28
Subba
Hi ghorrocks,
Thanks a lot for the reply.. I will try with an adjusted state file.. Thank you!
Old   September 23, 2023, 11:54
Gert-Jan
Gert-Jan will become famous soon enough
It is possible. 15 years ago I asked ANSYS for a once in a lifetime application. It is controlled somewhere in an editable file with defaults settings. But I don't remember.......
So please ask ANSYS again.
Gert-Jan is offline   Reply With Quote
Old   September 23, 2023, 12:03
Subba
Hi Gert-Jan,
ohhh great.. Thanks a lot for the info and sure, I will write to Ansys.. Thank you!
CFX post legend modification mactech001 CFX 3 December 25, 2011 23:12
CFX Post export problem jeff_F CFX 0 August 17, 2009 22:25
chart for transiente simulation - CFX Post rogbrito CFX 0 June 22, 2009 13:12
CFX 11, post Anant CFX 1 June 24, 2008 12:03
ANSYS CFX POST State file Mechstud CFX 1 June 22, 2007 15:59
