Plot Graph for CFX transient using as a Reference |
September 20, 2023, 07:57 |
Rakeshchandra
Rep Power: 6 |
I had gone through previous posts but could'nt find the suitable answer. I'm trying to plot Temperature vs Height using Line as reference for my transient analysis. In charts > XY-transient, the data source as a point is only available. Whereas in XY-Line, the datasource as line is available but is confined to single timestep. Any suggestions that how can I plot it across the complete simulation time?
September 20, 2023, 18:31 |
Rep Power: 144 |
I think you need to have a look at what you are trying to do.
In a transient simulation, if you get data at a point over time - then you have a 2D plot with the data in the y axis and time in the x axis. In a steady state simulation, if you get data at a line at one point in time - then you have a 2D plot with the data in the y axis and distance along the line in the x axis. If you have a transient simulation and you are trying to plot a variable over a line you now have 3 dimensions you are trying to plot (distance along line, the variable, time) - so a 2D cartesian plot is not longer suitable. How do you want to plot the third dimension? As a 3D surface? A series of lines? Multiple 2D cartesian plots?
September 21, 2023, 02:07 |
Rakeshchandra
Rep Power: 6 |
Thank you for explaining. I would like to plot the temperature vs. height as marked in the image across the simulation period of 360s. Could you please explain what I need to do if I want to utilize the lines as a reference?
September 21, 2023, 02:20 |
Rep Power: 144 |
I do not know of a good way to display this inside ANSYS or CFX. I would export it and use a graphing package like python (with matplotlib), matplot or excel to plot it.
You can automate the exporting of the data using a CFD-Post session file.
ansys 14 cfx, cel expression, cfx 15, plot over time, post procesing |
CFD-Post Expression transient graph plot takes too long time | apr13th | CFX | 3 | June 20, 2023 11:08 |
What are the best settings for a channel flow simulation? | Ashkan Kashani | CFX | 3 | October 13, 2022 21:36 |
[OpenFOAM.org] ParaView Installation: Python problem | KateEisenhower | OpenFOAM Installation | 5 | August 24, 2017 05:27 |
Simple piston movement in cylinder- fluid models | arun1994 | CFX | 4 | July 8, 2016 02:54 |
G95 + CGNS | Bruno | Main CFD Forum | 1 | January 30, 2007 00:34 |
