Oscillating Velocity Inlet BC
Like Tree2Likes
  • 1 Post By ghorrocks
  • 1 Post By Opaque
Old   March 12, 2023, 18:44
Default Oscillating Velocity Inlet BC
Eva Liu
evaliu246 is on a distinguished road
I am trying to model my inlet velocity as being created by a piston-cylinder going forwards and backwards in CFX. Where my velocity profile will be either a square or sine wave, zero, wave, zero, repeating. How can I do this using CFX
Thanks!
evaliu246 is offline   Reply With Quote
Old   March 13, 2023, 02:01
Set the boundary to an inlet, and define the normal or cartesian velocity as a CEL expression which defines your function, such as 10[m/s]*sin(10[Hz]*t*2*pi)
evaliu246 likes this.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   March 13, 2023, 10:28
Opaque will become famous soon enough
Just be careful with your expression. If your oscillating boundary condition has an always positive inflow, you can use INLET; however, if you expect reverse flow at some times, you are better off using OPENING.
Opaque is offline   Reply With Quote
inlet bc, oscillating flow, piston cylinder, velocity bc
Defined inlet velocity is different with inlet velocity on CFX post jonpewpew CFX 2 November 2, 2017 17:40
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
simpleFoam: Non-uniform mesh near inlet & outlet causes incorrect velocity profile? Zaphod'sSecondHead OpenFOAM Running, Solving & CFD 0 January 28, 2015 06:17
velocity inlet and ideal gas simultaneously-what's wrong? preetam69 FLUENT 0 September 28, 2013 05:51
UDF paraboloid velocity inlet Ronak Shah FLUENT 0 June 4, 2003 10:44
