How to use SST Curvature Correction
Like Tree1Likes
  • 1 Post By mike wilson
Old   November 7, 2007, 10:00
Default How to use SST Curvature Correction
mike wilson
Hi, I am looking at using the SST Curvature Correction in a flow simulation and am struggling to figure out how to use it! I have enabled the beta features, and now can not find where the curvature correction option is, would someone be able to give me some explanation of how to use it or point me in the direction of a tutorial? Cheers Mike
Old   November 8, 2007, 02:46
Default Re: How to use SST Curvature Correction
hdj
Hello Mike,
In CFX-11 go to Fluid Models in Domain definition. Then Turbulence Model - Shear Stress Transport, Advanced Control - SST Curvature Correction - on.
Regards
Old   November 8, 2007, 03:03
Wei Chen
hi hdj, As you suggestion, But I can't find the SST Curvature Correction all the same. In the CFX help, there have the option of SST Curvature Correction and SST Reattachment Modification. but i can't find in the CFX-pre, I don't know why? Regards
Old   November 8, 2007, 03:43
Alexey
You should export *.def file to *.ccl and modify it. There is no GUI for this option.
Old   November 8, 2007, 08:56
Wei Chen
Hi, Alexey, I have export *.def file to *.ccl file.but i don't know how to modify it. Could you please send me a *.def file or *.ccl file which you have the SST curvature correction? my email is: chenwei19840117@gmail.com Thank you very much!
Old   November 8, 2007, 09:52
mike wilson
would someone be able to correct this for me as I dont know how to edit the ccl files!
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
HEAT TRANSFER MODEL:
Option = None
END
THERMAL RADIATION MODEL:
Option = None
END
TURBULENCE MODEL:
Option = SST
TRANSITIONAL TURBULENCE:
Option = Fully Turbulent
END
END
TURBULENT WALL FUNCTIONS:
Option = Automatic
END
END
Thanks Mike
Old   November 9, 2007, 06:02
hdj
Hello Wei Chen,
First of all check out whether beta features are enabled. (Edit - Options - CFX-Pre - Physic Preferences - Enable Beta Features)
Regards
Old   November 10, 2007, 06:57
Wei Chen
Hi hdj, I have did what as you suggested. But there are still no SST Curvature Correction option.
Old   November 12, 2007, 07:40
mike wilson
Hi, I have the beta features enabled, but as there is no GUI for editing the curvature correction could someone tell me what i need to type into the command editor and where to turn the sst curvature correction on? Cheers Mike
Old   November 13, 2007, 02:46
hdj
Hello Wei Chen, Hello Mike.
Strange that you don't have a GUI for it, anyway here is that section in ccl:
TURBULENCE MODEL:
Option = SST
SST Curvature Correction = On
END
Regards
Old   December 18, 2010, 18:03
dean
ourdean is on a distinguished road
Hi everyone, I was wondering if anyone had the source code for the curvature and Rotation correction which i can eyeball and implement, I would really appreciate this please. Could you send/forward to ourdean@gmail.com
Cheers
ourdean is offline   Reply With Quote
Old   December 19, 2010, 17:04
CFX is a commercial package and the source code is not available. You will have to look at the references to academic articles listed in the documentation.
Floating point exception error Alan OpenFOAM Running, Solving & CFD 11 July 1, 2021 22:51
CFX Streamline Curvature Correction model flow.pratish CFX 8 August 29, 2012 19:32
Curvature Correction & Reattachment Mod. Felix CFX 5 December 19, 2010 17:04
Curvature and Rotation Correction ourdean Main CFD Forum 0 December 18, 2010 09:46
curvature correction term, material derivative of a tensor volker OpenFOAM Programming & Development 7 June 3, 2010 09:08
