How to define inlet boundary condition using perl or ccl or cel? |
January 22, 2023, 10:01 |
xiaolong li
Rep Power: 3 |
Hi, It is my first day on the forum, hope i can post the question correctly.
I am simulatiing an axial compressor cascade which works under transonic inflow conditions(inlet mach number is 0.8~1.2). The setup of inlet boundary condition is difficult because of the restrian of "unique incidence". Alternatively, the mach number and flow direction are high dependented. To get a correct value of mach number, i need moditied the inlet boundary condition manually. So i wander if i can edit the inlet boundary condition using perl or cel or ccl to achieve this goal automatically. Does anyone know how to help me? Thank you! |
January 23, 2023, 02:39 |
Daniel
Rep Power: 9 |
You can edit your CCL file automatically with a script (Python) and start the simualtion using normal batch files. That would be my approach.
January 23, 2023, 09:47 |
xiaolong li
Rep Power: 3 |
Thanks very much, have you done this task? Can you give me the detailed information to finish this. Hope can gain your reply!
January 23, 2023, 17:51 |
Rep Power: 144 |
From the CFX Launcher start a command line. Then use the command "cfx5cmds -read -def [def file name] -text [ccl file name]" to generate a ccl file. Edit the CCL to what you want and use the command "cfx5cmds -write -def [def file name] -text [ccl file name]" to put the ccl in your def file. You can then run it as normal.
You can also add a new ccl snippet when you run the solver, but I prefer the method I described previously as it generates a full ccl file which can be kept as a record of the settings for that run.
January 26, 2023, 02:34 |
#5 | |
xiaolong li
Rep Power: 3 |
My difficulty is that i dont know how to do the loop which can modify the boundary conditions automatically acording to the if condition. My previous method is using the perl, but it failed. |
January 26, 2023, 02:54 |
Rep Power: 144 |
CEL has an "if" statement. But be wary using it in defining boundary conditions for steady state runs, it is likely to make the simulation hard to converge. There is no looping functionality in CCL or CEL.
Reading your first post, what you propose to do sounds unusual and is likely to not be a good way of doing it. Please explain what you are trying to do and the output file of a simulation where you attempt to do it so we can understand what you are trying to do.
January 27, 2023, 06:31 |
#7 | |
xiaolong li
Rep Power: 3 |
Ok, i try my best to explain what i want to do. I want to simulate the compressor cascade in CFX. The hard thing is that the inlet boundry condition is not constant. In other words, the inlet Mach number and inlet flow angle are highly dependent. So if i want to achieve a target Mach number, i must modify the inlet flow angle manually. Therefore, i want find a method do this work automatically. Previously, i use the perl script and cel, but fariled. I search this in many website including the help document, still not find. Then, i come this forum to find the help. Best regards! |
January 27, 2023, 19:06 |
Rep Power: 144 |
By the way, I am not a professor
What you describe you want to do on the inlet sounds very unusual. Also, because you propose to change the inlet boundary condition during the run and this means you are going to have problems with convergence (if this is a steady state run). Almost always when somebody asks how to do an unusual thing in CFX what they are asking to do is a poor way of doing it and some totally different method is far better and avoids the original problem completely. Can you attach your failed attempts at doing this in perl or CEL/CCL? Then we might understand what you are trying to do a bit better.
January 28, 2023, 08:06 |
#9 |
xiaolong li
Rep Power: 3 |
OK, the following is my test script.
COMMAND FILE: CFX Pre Version = 18.1 END >load filename=D:/Gama29.cfx, mode=cfx, overwrite=yes > update LIBRARY: CEL: EXPRESSIONS: Ma=massFlowAve(Mach Number)@inlet END END END > update FLOW: Flow Analysis 1 DOMAIN: cascade BOUNDARY: inlet Boundary Type = INLET Interface Boundary = Off Location = ROW 1 _INFLOW BOUNDARY CONDITIONS: FLOW REGIME: Option = Mixed Blend Mach Number Type = Normal Speed END #FLOW REGIME: HEAT TRANSFER: Option = Total Temperature Total Temperature = 285 [K] END #HEAT TRANSFER: TURBULENCE: Option = Low Intensity and Eddy Viscosity Ratio END #TURBULENCE: END #BOUNDARY CONDITIONS: END #BOUNDARY:inlet END #DOMAIN:cascade END #FLOW: > update !$target_MachNumber = 0.86; !$inflowAngle = 29; !$Vel = 290; !while(1){ !if(abs(Ma-$target_MachNumber)>0.001){ BOUNDARY:inlet BOUNDARY CONDITIONS: MASS AND MOMENTUM: Option = Cartesian Velocity Components and Total Pressure Relative Total Pressure = 164162 [Pa] U = 0[m s^-1] V =$Vel*(sin(($inflowAngle+0.1)/180))[m s^-1] W =$Vel*(cos(($inflowAngle+0.1)/180))[m s^-1] END #MASS AND MOMENTUM END END }!else{ !last; } !} >writeCaseFile filename=D:/Gama29.def,operation=\ write def file > update |
January 28, 2023, 19:58 |
#10 |
Rep Power: 144 |
Are you trying to adjust the flow angle as the run progresses? Or just define it at the start of the run and it is fixed as the simulation proceeds. If you ae trying to adjust the flow angle inside the run this approach will never work because perl is evaluated once at the start of the run only. So your perl will not be updated as the run progresses, just once at the start of the simulation.
And in general, this is a poor way of doing it. It introduces problems of numerical stability and convergence. A MUCH better way of doing it is to do a series of simple simulations at a range of flow angles which are fixed as the simulation progresses. Then you take the results of these simulations and draw a performance vs flow angle curve and you can interpolate to the performance or flow angle you want. This is MUCH easier.
January 29, 2023, 20:57 |
#11 |
xiaolong li
Rep Power: 3 |
Yes, i understand you. But i have a lot of case to calculate. In your method, it will take much time. Thus, i try to make a script to release myself.
January 29, 2023, 21:05 |
#12 |
Rep Power: 144 |
Trust me, doing it at some fixed angles and interpolating will be MUCH faster and easier than doing it inside the simulation as you propose. In fact I bet you never get it working inside the simulation at all, so it is the difference between getting a result and getting nothing.
January 30, 2023, 09:56 |
#13 |
Rep Power: 33 |
If you are trying to obtain a performance curve/map for your model, you can use the "operating points" feature. It should be a trivial exercise of setting which parameters you want to study, a set of values of interest and the software will do all the simulation in one go for you.
January 30, 2023, 10:20 |
#14 |
xiaolong li
Rep Power: 3 |
ok, i will try, thanks.
July 27, 2023, 07:48 |
ccl file addition in cfx5solve
#15 |
prashant godse
Rep Power: 3 |
how to add ccl file to .def using perl in cfx5solve
July 27, 2023, 12:38 |
#16 |
Rep Power: 33 |
cfx5cmds -help
Using UDF to define velocity gradient boundary condition (not velocity inlet profile) | uconcorde | Fluent UDF and Scheme Programming | 3 | December 11, 2023 13:56 |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 19:02 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 01:00 |
Installing OF 1.6 on Mac OS X | gschaider | OpenFOAM Installation | 129 | June 19, 2010 10:23 |
Missing math.h header | Travis | FLUENT | 4 | January 15, 2009 12:48 |
