December 20, 2022, 11:47 |
Solution error
chaimbo
Rep Power: 3 |
Hello, I am trying to analyze on a centrifugal compressor. I meshed with Turbogrid. I need to choose ideal gas for my fluid on the loading screen, but the application gives an error at step 7 in the solution section. If I make the gas 25 degrees air, there is no problem. But I need ideal gas. I tried everything and couldn't solve the problem.
Thanks.. |
December 20, 2022, 16:54 |
Rep Power: 33 |
It would be great if you were a bit more precise in your description.
Which application are you using when "loading screen"? CFX-Pre? If so, which mode did you select when opening? General/Turbomachinery? Which set of instructions are you using that refers to "step 7"? Is it a provided tutorial?, or video? or else?
December 21, 2022, 07:56 |
Solution Error
chaimbo
Rep Power: 3 |
Thank you for your interest, I do not speak English. That's why I use translation.
My sentences may sound a little garbled or incomplete.Let me explain what I do in order. First, I designed the compressor from the application called CFTurbo, then I transferred this design with ansyse turbogrid. I connected the turbogrid with turbo mesh and connected it with cfx. After the turbo mesh step, there is a setup step in the cfx section, I need to choose my fluid ideal gas in the setup, and my parameters are 288.15 kelvins, my inlet pressure is 0 atmosphere inlet temperature. My outlet flow is 0.6 kg/s and my initial pressure is 1 atmosphere. After confirming these, I save and move on to the solution section. The solution starts and after a little progress, all the variables suddenly increase excessively and I get an error. I will leave a picture of it here. When I do the same things with 25 degrees air, not ideal gas, I do not get an error. When I said step 7, I didn't mean step 7 that I applied. 7th step of iteration. I do 300 iterations in total. |
December 21, 2022, 11:12 |
Daniel
Rep Power: 9 |
It would be helpful if you provide your .out file of your simulation. There, the error warning of the solver is written.
December 21, 2022, 12:30 |
solution error
chaimbo
Rep Power: 3 |
where can i find out file?
December 22, 2022, 02:25 |
Daniel
Rep Power: 9 |
If you are working in Workbench, your CFX Node should look like the attached image.
Click on "Solution" and you can see your residuals on the left and your .out-File Data on the right. If you are working in stand-alone, an .out-File will be generated simultaneously with your result file. |
December 22, 2022, 06:21 |
solution error
chaimbo
Rep Power: 3 |
December 22, 2022, 07:07 |
Daniel
Rep Power: 9 |
Is your inlet total pressure correct ?
Is it correct, that your model is subsonic ? |
December 22, 2022, 07:20 |
#9 |
chaimbo
Rep Power: 3 |
I'm not sure about these. I don't know what subsonic means, I haven't touched it. but the inlet pressure will be 0 atm
December 22, 2022, 07:39 |
#10 |
Daniel
Rep Power: 9 |
This is basic fluid mechanics and you should have a look at these basics before carring out a CFD simulation.
But, the solver shows a fast increase of the Mach Number in your setup, which results in an overflow error. Your boundary conditions should be checked. Do you have any real purpose for this simulation ? |
December 22, 2022, 07:49 |
solution error
#11 |
chaimbo
Rep Power: 3 |
yes i have a purpose this is my design assignment. I just changed my rev count from 90000 RPM to 40000 RPM and it's analyzing now. Is the mistake here?
but my speed should be 90000rpm |
December 22, 2022, 07:59 |
#12 |
Daniel
Rep Power: 9 |
Unclear. Your Mach number will probably go down.
Does the solver show a message after every iteration that the Mach number is at a speicfic value ? Where did you get the 90'000 rpm ? Your compressor will probably operate under transonic or supersonic conditions with this speed. |
December 22, 2022, 08:14 |
solution error
#13 |
chaimbo
Rep Power: 3 |
First of all, my teacher gave me the necessary values about design. It gave a speed of 90000 RPM, a flow rate of 0.6 kg/s and a pressure ratio of 4.5. I'm trying to design accordingly. If it is as you say, if I am going to make it supersonic or transonic, what values should I enter in the parts there?
I need to make supersonic for both input and output, right? |
December 22, 2022, 08:29 |
#14 |
Daniel
Rep Power: 9 |
Can you, please, go into your impeller Domain R1 and change the Heat Transfer from adiabatic to Total energy. Try the simulation again.
December 22, 2022, 08:31 |
solution error
#15 |
chaimbo
Rep Power: 3 |
total energy already selected
but there is an option just below. Should I leave the option on or turn it off? I can try with supersonic or mixed but I don't know what values to enter |
December 22, 2022, 12:36 |
#16 |
chaimbo
Rep Power: 3 |
can you help my problem? please
December 23, 2022, 02:12 |
#17 |
Daniel
Rep Power: 9 |
sadly, I'm not an expert carrying out transonic or supersonic simulations. But, there is an FAQ
which you should check out and compare with your setup. https://www.cfd-online.com/Wiki/Ansy...do_about_it.3F Also, do you have an inlet and outlet domain for your impeller ? |
December 23, 2022, 04:56 |
solution error
#18 |
chaimbo
Rep Power: 3 |
According to the values I entered in the program I designed, I think I can take a photo of that part.
p.zip What does the analysis with 70 rpm and not doing the analysis at 80 and above indicate? |
December 25, 2022, 12:08 |
solution
#19 |
chaimbo
Rep Power: 3 |
ı am impeller
cfx & fluent, solution error |
[swak4Foam] swak4foam openfoam 7 installation problem | Andrea23 | OpenFOAM Community Contributions | 1 | February 17, 2020 18:11 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 09:30 |
How to get the max value of the whole field | waynezw0618 | OpenFOAM Running, Solving & CFD | 4 | June 17, 2008 05:07 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
