Explicit CEL variables
Like Tree1Likes
  • 1 Post By ghorrocks
Old   November 16, 2022, 09:25
Question Explicit CEL variables
Juan Luis
juanluisfb is on a distinguished road
Hi everybody,
Anyone knows how can you use explicit variables in CEL? Or, is it possible to access variables or properties of previous time steps?
Thank you.
juanluisfb is offline   Reply With Quote
Old   November 16, 2022, 17:28
What do you mean by explicit variables? Example = 10[m/s]+2*Velocity is an explicit variable.
Can you access variables from previous time steps? This is not supported, but there is a unsupported method of doing it: see
Update Loop = TRANS_LOOP
Why the Trans_Loop trick does not work? No old time value obtained!
Note it is pretty unreliable and does not work in every case (that is why it is unsupported)
Alternately you can write some user fortran to do it.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
ghorrocks is online now   Reply With Quote
Old   November 16, 2022, 17:38
Opaque will become famous soon enough
adding to Glenn's question:
what are you trying to achieve that needs variables at previous timesteps?
Opaque is offline   Reply With Quote
Old   November 17, 2022, 10:17
Juan Luis
I have a CEL expression that have to be evaluated with variables at the previous step. An example of this could be a temperature ON/OFF control.
Old   November 17, 2022, 18:15
It would be good if you described what you are actually trying to do because there usually is a better way of doing it.
But to answer your question: You cannot do temperature on/off control in a steady state simulation as it will never converge. If you want to do it in a transient simulation you can try the TRANS_LOOP approach or a user fortran routine, as previously suggested.
Opaque likes this.
cel expression
Mesh displacement failed with User CEL Functions motorbean CFX 2 July 11, 2022 06:33
[swak4Foam] How to define boundary condition variables by using previosly defined variables? pawlo OpenFOAM Community Contributions 8 September 13, 2020 12:37
CFX CEL Expression for Cavitation Modeling kimotbwb CFX 2 March 28, 2018 04:26
CEL vs. USER FORTRAN Zaktatir CFX 0 February 16, 2013 07:29
CEL Position Dependent Variables in CFX-Pre njw CFX 2 November 20, 2011 06:11
