MANU P ANAND
Rep Power: 12 ![]() |
I am currently meshing an impeller geometry using turbo grid. i have some doubt. How to increase the division of elements from shroud to hub? (check err 33.png )
I have some other errors also tried to refine edge. I had refined it to 100%. (check err 32.png,34,35 ) How to clear my error in edge length ratio. I had referred Turbo grid user guide. but I am unable to solve it. There is also error in blade surface. |
Daniel
Rep Power: 9 ![]() |
To increase the elements in the passage, go to into the Mesh Data and the second tab should be named "Passage" there you can switch between three options to define your passage elements.
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 00:21 |
Pressure outlet boundary condition | rolando | OpenFOAM Running, Solving & CFD | 62 | September 18, 2017 06:45 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 17:38 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
