solving flow in axial compressor stages with no convergence |
Bassam Elsayed
Rep Power: 4 ![]() |
Hi every one, I try to solve a flow inside axial flow compressor stage (IGV, Rotor and Stator). the solver appears to not converge but RMS goes steady and straight fluctuating around 10E-3. i tried several times(200 -400 - 500 - 1000) iterations but i have the same results.
the model inlet conditions is total pressure 1.13 atm. and temperature 288 K, while the outlet is mass flow rate 77 kg/s. the turbulent model is K-E.. Also the efficiency seams that it oscillates and damped with number of iterations. I wanna to know what may cause this issue and how i can fix it to have converged. |
Daniel
Rep Power: 9 ![]() |
First, please, check the maximum Residuals in your output file. These will indicate the domain, where they occur. You can place a point at the exact node number. This will help identify in which region you have convergence issues.
Afterwards, please, recheck your mesh to properly resolve the regions you have encounted that show high residuals. Maybe you can post an image of your domain setup as well. |
Rep Power: 144 ![]() ![]() ![]() ![]() |
chtMultiRegionSimpleFoam: maximum number of iterations excedeed. | Nkl | OpenFOAM Running, Solving & CFD | 19 | October 10, 2019 02:42 |
a problem with convergence in buoyantSimpleFoam | skuznet | OpenFOAM Running, Solving & CFD | 6 | November 15, 2017 12:12 |
conjugate heat transfer in OpenFOAM | skuznet | OpenFOAM Running, Solving & CFD | 99 | March 16, 2017 05:07 |
Cannot run the code properly: very large time step continuity error | crst15 | OpenFOAM Running, Solving & CFD | 9 | December 14, 2014 18:17 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
