How to model a sphere in DesignModel of Ansys?
Like Tree4Likes
  • 1 Post By Li
  • 1 Post By CycLone
  • 1 Post By Li
  • 1 Post By Li
Old   September 14, 2007, 13:29
Default How to model a sphere in DesignModel of Ansys?
Li
Hej Greetings! I am trying to model a sphere in DesignModel of Ansys, but now I don't know how to generate a solid sphere, I only get the surface of the sphere through revovling the circle. Would anyone know how to do it? Thank you very much!
Regards, Li
nepomnyi likes this.
Old   September 14, 2007, 16:08
Default Re: How to model a sphere in DesignModel of Ansys?
CycLone
1. Create>Primitives>Sphere 2. Revolve a 180 degree arc, not a circle.
wenshenghu likes this.
Old   September 15, 2007, 08:20
Li
Dear CycLone,
Regards, Li
Old   September 15, 2007, 09:05
Li
But it is solid if I use Create>Primitives>Sphere, then would you tell me why I should use Revovle again? And if I want to model a solid with the following frame( in the website link), would you tell me how to do it? I don't know how to chamber it. Thank you very much!
http://imageshack.dk//viewimage.php?...e/Uup57908.png
Regards, Li
Old   September 15, 2007, 16:26
Anantha
Hello Li, if you are using Primitive solid you need not revolve the half circle again. Mr CycLone has suggested two possible options.
For you to create the image shown, one option is to create the sketch of the half cross section and then revolve it 360 degree. The sketch can include the arc representing the fillet. Or else create two cylinders, apply boolean operation to unite it and then apply fillet. For a geometry you can find many ways of doing it.
Regards Anantha
Old   September 16, 2007, 12:05
Li
Hej Anantha, thank you very much for your post. Yeah, I tried to create the sketch and then revolve it, but it just a surface, not a solid. I will try the second suggestion. Thanks a lot!
Regards, Li
Old   September 17, 2007, 09:23
Li
Hej, I got it. When the sketch is closed, then it would be a solid after revolving. Thank you very much, CycLone and Anantha.
Regards, Li
Old   March 6, 2013, 04:21
Smile I need some instrumentals of the design model
huzi
wenshenghu is on a distinguished road
Hi, I am a beginner in the learning of design mdel , Can anybody help me with that? Thanks!
wenshenghu is offline   Reply With Quote
Evaporation model in ansys Fluent 12.1 oldisbest Fluent UDF and Scheme Programming 12 March 26, 2020 10:11
about Subgrid-scale model impecca OpenFOAM Running, Solving & CFD 4 December 20, 2013 11:36
Low Reynolds k-epsilon model YJZ ANSYS 1 August 20, 2010 14:57
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 26, 2009 00:27
DPM model w/ Wave model - errors in documentation HS FLUENT 0 April 12, 2006 05:37
