September 30, 2022, 04:12 |
Is there a simple way to find a node number?
Vinicius Alves
Hi, I'm running an FSI simulation coupling CFX with Mechanical, and one of the monitor points I set is the Total Mesh Displacement of an specific mesh node.
The problem is that, to set this monitor, I need to know the node number of that node. But I don't really know an easy way to find it (I searched through the documentation and find nothing about this). I discovered that I can set a point to a node number at CFD-Post, so I used this to find a node nearby the region I needed, but this is very impractical as I had to set the point to multiple points until I found one that suits me, and if I change the mesh I would need to do this again. Is there an easier way to find it? Or an easier way to get the Total Mesh Displacement of an specific point of the mesh? |
October 8, 2022, 04:27 |
Rep Power: 144 |
Can't you define a monitor point by x,y,z location, and use the nearest node option? Then select the option for the monitor point to move with the mesh and you can get the displacement of that mesh node without ever knowing what the node number is.
October 12, 2022, 00:19 |
Ashkan Kashani
Rep Power: 10 |
You can display node and cell numbers in Tecplot.
In Tecplot, follow Plot >> Label Points and Cells and then check Show node labels and Show cell labels. I am not aware of any other method to do that. |
October 25, 2022, 08:31 |
Vinicius Alves
Yes, defining the monitor point by coordinate solves my problem! Thank you for the answer. I only had to set the Position Update Frequency to "Initial Mesh Only" so that the node doesn't change during the simulation.
fsi 2-way, mesh displacement, monitor point |
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' | BrendaEM | OpenFOAM Meshing & Mesh Conversion | 12 | April 3, 2022 18:32 |
SimpleFoam & Theater | jipai | OpenFOAM Running, Solving & CFD | 3 | June 18, 2019 10:11 |
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) | AndreP | STAR-CCM+ | 10 | August 2, 2018 07:48 |
foam-extend_3.1 decompose and pyfoam warning | shipman | OpenFOAM | 3 | July 24, 2014 08:14 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
