August 3, 2022, 18:10 |
Cannot compile user FORTRAN
Rodrigo Villarreal
Rep Power: 10 |
Hello everybody! I'm trying to compile the first tutorial on user FORTRAN (parabolic profile in inlet) but the following message appears when I'm trying to compile the user function from cfx command line.
ifort: command line warning #10434: option '/real_size' use with underscore is deprecated; use '/real-size' instead ifort: command line warning #10434: option '/integer_size' use with underscore is deprecated; use '/integer-size' instead usr_velfunc.F(107): error #6717: This name has not been given an explicit type. [RET] CALL SET_A_0( RET, NLOC*NRET ) --------------------^ usr_velfunc.F(107): error #6717: This name has not been given an explicit type. [NLOC] CALL SET_A_0( RET, NLOC*NRET ) -------------------------^ usr_velfunc.F(107): error #6717: This name has not been given an explicit type. [NRET] CALL SET_A_0( RET, NLOC*NRET ) ------------------------------^ usr_velfunc.F(110): error #6717: This name has not been given an explicit type. [ARGS] CALL SET_A_B( RET, ARGS, NLOC ) -------------------------^ usr_velfunc.F(113): error #6717: This name has not been given an explicit type. [CRESLT] CRESLT = 'GOOD' ------^ compilation aborted for usr_velfunc.F (code 1) An error has occurred in cfx5mkext: C:\Program Files (x86)\Intel\oneAPI\compiler\latest\windows\bin\int el64\ifort exited with return code 1. Does anyone know how to fix this? I'm using Visual Studio 2022 and Intel oneAPI 2022 Thank you in advance. |
August 3, 2022, 20:50 |
Rep Power: 144 |
It looks like those variables have not been defined. The example has them defined a few lines before the line flagged with an error. Are you sure you have included the whole example file in your case?
August 6, 2022, 21:23 |
Rodrigo Villarreal
Rep Power: 10 |
Thanks for your kind answer. I just found that I added one extra end statement in between two commentaries. After erasing it, everything worked fine!
August 6, 2022, 21:48 |
Rep Power: 144 |
If you use a code editor to write your fortran rather than a plain text editor errors like this become obvious. So make sure you are using a code editor which understands your version of fortran.
August 7, 2022, 01:01 |
Rodrigo Villarreal
Rep Power: 10 |
Thanks, it is good advice.
cfx, cfx + fortran, user cel function |
adding velocity fluctuations on inlet by user fortran | Sergeyevichsky | CFX | 2 | May 18, 2017 23:42 |
User fortran to input/output file in a parallel run | doublestrong | CFX | 5 | March 31, 2017 09:15 |
problem about user fortran | xyq916 | CFX | 0 | January 27, 2015 08:38 |
user routine, user funcion, or fortran compile effect on the memroy? | princeps11 | CFX | 1 | May 13, 2009 19:37 |
User Fortran and Particle momentum source | alvio | CFX | 0 | July 30, 2008 23:52 |
