Multiple isolated fluid regions were found in domain - CFX |
July 11, 2022, 05:14 |
guest1104
I have a larger body (fluid domain) within which there are couple other smaller bodies that I want to use as subdomains. But when I import the mesh, the domain in CFX-pre has multiple assemblies in location. This is resulting in the solver running into an error- "3 isolated fluid regions were found in domain Domain 1".
Can someone help me sort it out? |
July 11, 2022, 05:30 |
Gert-Jan
Rep Power: 27 |
You should put all volumes in the main domain and on top of that define subdomains for the smaller bodies.
This should work fine unless your volumes are not connected properly and don't have a conformal mesh. But that is impossible to judge without more information. You should share more info (pictures!) on your geometry, how is was created, meshed, imported, etc. |
cfx solver, cfx-mesh, cfxpre |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Can I achieve better convergence? | sheaker | CFX | 12 | September 19, 2019 15:36 |
[Other] Mesh Importing Problem | cuteapathy | ANSYS Meshing & Geometry | 2 | June 24, 2017 05:29 |
Sudden increase the residual of Maxwell's equations | hsezsz | CFX | 2 | October 13, 2016 06:58 |
how to assign multiple fluid domain with different | jai | CFX | 1 | March 10, 2009 03:01 |
