import airfoil in Bladegen
Like Tree1Likes
  • 1 Post By Robin
Old   August 1, 2007, 11:49
Default import airfoil in Bladegen
SERGIO
Hi I' have an airfoil in (x,y) coord.
how can I import?
I tryed to have beta definition by geomtric analysis but I have a bad curve.
Someone could explain correct method?
thamk's
Old   August 1, 2007, 13:04
Default Re: import airfoil in Bladegen
Santiago Orrego.
Hi. Try to cretaing the curve in a CAD software (Catia, ProE, Solidworks...). You have to import the points that define the curve, and create the curve.
Then export the curve to .IGS (.IGES). Then in blade gen, import the curve that define the airfoil.
Old   August 2, 2007, 03:22
sergio
I tried but my airfoil have very sharp LE &TE so when I import by wizard the software make an elliptic end , so Ihave bad airfoil
Any other suggetion?
Old   August 2, 2007, 10:16
Robin
BladeGen will always represent the leading and trailing edges as ellipses or cut-off. If you have a sharp leading or trailing edge, just specify the ellipse size to be very small, but not zero.
To import you profile points into BladeGen, have a look at the TurboGrid .curve format or the RTZT format. Both are documented in the on-line help.
Regards, Robin
akbari likes this.
bladegen data import issues sanandtv CFX 8 April 2, 2016 06:16
Creat or Import 2D airfoil profile. Jackie FLUENT 14 May 11, 2013 07:16
BladeGen: problem with geometry import famarcfd ANSYS 0 December 10, 2010 03:12
Import an airfoil to ANSYS workbench NAJEM FLUENT 0 November 3, 2009 15:12
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
