CFX Post User Surface
Like Tree1Likes
  • 1 Post By Robin
Old   July 20, 2007, 03:41
Default CFX Post User Surface
OliH
I'd like to create a rectangular user surface with extents defined by certain lines. It seems simply but does anyone know how to do this??
Thanks in advance,
Oli
Old   July 21, 2007, 12:51
Default Re: CFX Post User Surface
Jinji
I'm doing this sort of things defining new parts in ICEM (or whichever mesher you're using). But maybe there's away also directly in the postprocessor in this moment I don't know it!
Old   July 23, 2007, 10:25
Robin
If it is a flat surface, just create a plane by point and normal, with the point being the center of the desired surface, and set the Plane Type to Sample (Plane Type is defined under the Geometry Tab of the Plane object). You can then specify the plane bounds to be the dimensions you desire.
If you want to create an arbitrary surface with curved edges, it cannot be done directly in Post. If you can create and mesh the surface elsewhere, it is possible to get it into Post using the User Surface format.
Regards, Robin
E S likes this.
Old   July 23, 2007, 10:35
Robin
Hi Oli,
What is the purpose of this surface? Are you trying to extract data from a specific region or simply add geometry for visualization?
Regards, Robin
Old   August 27, 2012, 05:18
Ivailo Rusev
et1ap2 is on a distinguished road
Hi all,
I try to create user surface from file. Could someone explain how the *.csv file should look like? I have already imported polylines around the contour of a building with irregular shape (in every 5m in height), so I can use their coordinates to define the user surface. My goal is to define a user surface as near as possible to the building`s surface, but the height of the user surface should be less of the building`s one.
Thank you in advance,
Rusev
et1ap2 is offline   Reply With Quote
CFX convergence issues with free surface adenlan CFX 3 September 2, 2011 07:43
viewing cfx post while working on cfx solver manager HMR CFX 5 March 9, 2011 23:33
User surface creation in CFX post Vicky88 CFX 3 January 28, 2011 06:34
CFX 10 User Routine NOT in Fortran Andre CFX 14 August 9, 2006 00:03
CFD Short Course & CFX User Day Chris Reeves CFX 0 September 11, 2000 09:53
