Fatal Overflow in Linear solver.
Like Tree1Likes
  • 1 Post By Gert-Jan
Old   March 7, 2022, 10:38
Question Fatal Overflow in Linear solver.
Gokkul Raj
Gokkul is on a distinguished road
Hello everyone
I am doing steady state 3D simulation for turbine. Before assembling the whole turbine, I tried simulating only the first stator. Everything was fine and I was able to get results. But when I am trying after assembling 2 stage turbine, I am getting errors like "Floating point exception: Overflow" or "Fatal Overflow of linear solver" before 10th iterations. So I tried simulating the first rotor alone, I am getting the same error. The mesh analysis has no error and even in the CFX solver, under mesh statistics, everything says OK. I tried using different mesh from coarse to very fine mesh. I am using SST for turbulence model. I can see that only the rotor has the error. It would be great if someone could assist me in this situation. If needed I can share my mesh file or CFX file.
Thanks in advance!
Gokkul is offline   Reply With Quote
Old   March 7, 2022, 14:46
Gert-Jan
Gert-Jan will become famous soon enough
For these kind of questions, we kindly refer to the following link:
https://www.cfd-online.com/Wiki/Ansys_FAQ#CFX-5
Gert-Jan is offline   Reply With Quote
Old   March 7, 2022, 14:53
Gokkul Raj
Hello Gert
Thanks for the response. I will look into the link.
Also, with the same rotor geometry and mesh, when I tried Air at 25C as fluid the simulation ran without any errors. The error pops up when I use Air as Ideal Gas. That's why it was very confusing and don't know where exactly the problem is!
Old   March 7, 2022, 16:53
Gert-Jan
The source of error can be anywhere. Changing from constant properties to properies that depend on Temperature and Pressure is a huge step. Even since I don't know what Energy model you use (None, Thermal, Total)
I would suggest to start gently with low rotor speed and ramp up slowly and increase other complexity step by step. Don't try to hit the top in one go.
Opaque likes this.
Old   March 7, 2022, 18:06
Opaque will become famous soon enough
As Gert said, the error can be anywhere, so it is best to start slow and with controlled variables/degrees of freedom.
Pick a mesh first (regardless of accuracy), set up the physics, and try to obtain some results in it. Practice different settings to understand how they influence the path of convergence (read the modeling guidelines for help).
Attempting to change multiple parameters w/o knowing what they will achieve will not get you anywhere.
For steady-state, I will select the AutoTimescale option unless you understand how to use and compute an appropriate Physical Timescale. Read the documentation about what the diagnostics in the output file mean. Those numbers are not written to show progress, but how it is progressing and indicate the level of difficulty encountered when solving your problem.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Opaque is offline   Reply With Quote
Old   March 8, 2022, 04:34
Gokkul Raj
Hello Gert and Opaque
Thanks a lot for your valuable comments. I will try to implement it in my simulation!
Also, I created backup file before the error and when I was post-processing the results, the magnitude of velocity is too high (1.9e3).
Old   March 8, 2022, 20:54
This is typical in a diverging simulation. Look at the FAQ quoted by Gert-Jan for general tips on what to look at. Some of the other FAQs (eg the one on "Floating point error") are also relevant - you don't quite have a floating point error yet, but you are approaching it if it is diverging.
cfx, rotor, turbomachines
Divergence detected in AMG solver. VOF. Mr.Mister Fluent Multiphase 4 September 25, 2023 08:10
Fail to converge when solving with a fabricated solution zizhou FLUENT 0 March 22, 2021 07:33
Fatal overflow in linear solver and simulation never show convergence Wong0912 CFX 1 March 2, 2021 17:59
Fatal overflow in linear solver error. Why? zaidun CFX 7 August 11, 2016 06:59
2D isothermal cylinder not converging UPengineer OpenFOAM Running, Solving & CFD 7 March 13, 2014 06:17
