Cfx does not respond when reading ccl
Like Tree1Likes
  • 1 Post By Gert-Jan
Old   March 3, 2022, 08:22
Default Cfx does not respond when reading ccl
Dimitrios S. P.
Pled is on a distinguished road
I have a relative large ccl file.
CFX does not respond when reading it, however, when forcing it to close and reopening, it shows that everything within the ccl have been read.
What can I do about it?
Pled is offline   Reply With Quote
Old   March 3, 2022, 10:50
Gert-Jan
Gert-Jan will become famous soon enough
Where do you import (not read) the ccl? In CFX-Pre?
And when do you do it? Before the mesh import, or after? If so, do you overwrite the existing setup?
And what does the ccl contain exactly? If you have a complicated geometry with a dozens of surfaces, then it might take a while.....
Please be more sepcific.
Opaque likes this.
Gert-Jan is offline   Reply With Quote
Old   March 4, 2022, 05:04
Dimitrios S. P.
I upload it to the cfx-pre after mesh import.
However, after several minutes it finally succeeds to reads it.
Old   March 4, 2022, 05:19
Gert-Jan
Seems you just have to be patient or buy a faster computer.
Alternatively, in CFX-standalone, you can
- import the mesh in Pre.
- write a def-file and close Pre.
- open the command line from the CFX-launcher > Tools
- give the following command: cfx5cmds -write -def <file.def> -txt <file.ccl>
- Open the .def-file in Pre.
This is an alternative way of changing the contents of your def-file. Not sure if this is faster. Especially, opening a def file with a ccl-file that does not match completely might give unexpected errors.
If you are experienced in this route and get no errors at all, you don't even have to reopen the .def file, but pass it directly to the solvermanager and start running.
All outside Workbench.
Old   March 4, 2022, 17:54
Did you say it took several minutes to load? What is the problem with that? That sounds fine to me, you just need more patience.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
ccl, cffx, script
[Commercial meshers] Problem converting fluent mesh vinz OpenFOAM Meshing & Mesh Conversion 28 October 12, 2015 07:37
Reading data from CFX result file sujay CFX 3 May 27, 2014 20:06
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
Reading CFX-CFD results without Ansys CFX JAY ANSYS 2 July 7, 2009 17:48
[Commercial meshers] FluentMesh conversion problem waynezw0618 OpenFOAM Meshing & Mesh Conversion 12 December 1, 2006 00:12
