April 15, 2007, 09:42 |
import data from CFX-post to MATLAB/EXCEL
hi, can u give the procedure to import the data from CFX-post to MATLAB/EXCEL to plot the graph & do the calculation.
April 15, 2007, 12:47 |
Re: import data from CFX-post to MATLAB/EXCEL
Create a graph on the CFX post, and when you decide what you plotted, there is a button that says EXPORT.
April 17, 2007, 10:45 |
1. You can do it the way Sze Hong says, by plotting the chart and then exporting
2. Or once you have created your point/line of interest. Just press file ---> export--- in csv format, and you have it in EXCEL. ( You cannot export transient results this way though, i think) Then if you want, you can import your values from excel to MATLAB easily. |
April 21, 2007, 12:12 |
what is the procedure to find coefficient of lift
what is the procedure to find the coefficient of lift from velocity vs chord length graph? or pressure vs chord length graph?
April 28, 2011, 02:48 |
Darren Leong
Rep Power: 15 |
Hi guys,
I need help on this too. I have transient run in which i would like Matlab to graph the location of a moving body (X,Y,Z), along with the forces and moments acting on it. So far, I've set up the monitor plots in which the data is stored in *.out files for each time step. The data sitting in front of me on screen, however I haven't the clue to how to graph them out using Matlab, e.g. Collating them into one data file for plotting or reading the values from each .out file as it plots the graph. Edit: Just to clarify what i mean is through script rather than manually (e.g. using the mouse) in Matlab. |
May 24, 2011, 05:26 |
Rep Power: 15 |
I use the export function to export the results in a .csv file. You have to set a location from which it exports the results, so it is always recommended to view the results first in a chart and then export them to a .csv file. Make sure you don't add the header, you can unselect it on the second tab of the export screen, otherwise you have to manually set the rows and columns of the data for Matlab to work.
Use csvread in Matlab to load the results in your workspace. You can check 'help csvread' on how to do that. Cheers! |
May 26, 2011, 00:39 |
Darren Leong
Rep Power: 15 |
Thanks, Kartus. I've managed to do as you've suggested
Results_002 = csvread ('Analysis_Results_002.dat',1,0); It would have been good to have the labels read, would save me time to manually include them in the plot, e.g. Timestep = Results_001(:,1); Mesh_Quality = Results_001(:,2); Sphere1_Force_X = Results_001(:,3); Sphere1_Force_Y = Results_001(:,4); Sphere1_Force_Z = Results_001(:,5); Sphere1_Moment_K = Results_001(:,6); Sphere1_Moment_M = Results_001(:,7);... and so on |
May 26, 2011, 05:01 |
Rep Power: 15 |
To my knowledge it is not possible to read anyhting else then values from a csv file using csvread.
I can't help you with the labels, I add all the labels manually in an m-file and load all the results for different cases from that file. It is a copy-paste solution, not very elegant... |
March 4, 2013, 09:29 |
#9 |
amin gls
Rep Power: 14 |
hello. i have a question about this . when i export to .csv file and opens it with excel . the data are in different rows and just one column .for example x1 and v1 are in first column i want to be x1 in fist and v1 in second column . how can i do it . thanks for help .
March 4, 2013, 10:02 |
#10 |
Lance
Rep Power: 22 |
This is really not a CFX issue, but here goes...
It would be something like: Data/From text/<find your file>/Delimited/<next>/Delimiters: comma/<finish> |
March 5, 2013, 02:28 |
#11 |
amin gls
Rep Power: 14 |
September 13, 2016, 08:16 |
#12 |
Thomas B
Rep Power: 10 |
I know this thread is very old, but I might have the same issue: I have several defined points (like 100 or so), several reference temperatures (one for each point). For each point, a heat transfer coefficient is computed using the formula: What interests me is the weighted average of these HTC's (therefore I cannot use the "monitor point method"): This value only depends on time: I want to export the datas to MATLAB. For this purpose, I need the .csv file. Thing is, as far as I know, we can do that with the "export" command in CFX Post only for a given time step. But I have the chart plotted. Is there a way to get the .csv file direct from the chart? Or do I have no other choice but to write some script to loop over the time steps to retrieve for each one of them the value of ? Last edited by Thomasbr; September 13, 2016 at 10:00. |
September 15, 2016, 08:32 |
#13 |
Thomas B
Rep Power: 10 |
I finally managed to do what I wanted to, that is, to get a .csv file with the time (in my case variable name = TimeVar) and the value of (in my case variable name = AAlphaGesVar) for each time. This might interest someone, so I describe what I did (I learnt a bit of Perl too):
data.csv looks like this: Code:
9.89989028e-004, 5.02314758e+000 1.02000998e-003, 5.10743713e+000 1.05003000e-003, 5.00016737e+000 1.07995002e-003, 4.82792759e+000 1.10997004e-003, 4.82947874e+000 ... Code:
COMMAND FILE: CFX Post Version = 16.0 #Enter your version of CFX Post here END !use strict; !use warnings; !open (OUTFILE, ">", "data.csv"); !for (my $i=34; $i<=169; $i++) !{ # Start for loop to load different time step # One need to modify it based on his/her need !my $resstp=$i; DATA READER:DATA READER Current Timestep = $resstp END > load EXPORT: # export data to test1.csv ANSYS Export Data = Element Heat Flux ANSYS Reference Temperature = 0.0 [K] ANSYS Specify Reference Temperature = Off ANSYS Supplemental HTC = 0.0 [W m^-2 K^-1] BC Profile Type = Inlet Velocity Export Connectivity = Off Export Coord Frame = Global Export File = test1.csv Export Geometry = Off Export Node Numbers = Off Export Null Data = Off Export Type = Generic Export Units System = Current Export Variable Type = Current Include File Information = Off Include Header = Off # One can turn header off if it is wanted Location List = P22 #The value of my variables does not depend on the location, so I put any point here, just modify it based on your need Null Token = 0 Overwrite = On # One should turn the Overwrite On Precision = 8 Separator = ", " Spatial Variables = X,Y,Z Variable List = TimeVar, AAlphaGesVar Vector Brackets = () Vector Display = Scalar END >export !open (INFILE, "<", "test1.csv"); !print OUTFILE <INFILE>; # copy data in test1.csv to output file, which is data.csv !close INFILE; !} !close OUTFILE; Under CFX Post I clicked on "Session" then on "Play Session" and selected the .cse file. After a couple minutes the file data.csv was written. Last edited by Thomasbr; September 15, 2016 at 10:41. |
July 5, 2017, 07:26 |
#14 | |
How did you manage to get all your required variables into one dat file so that matlab can read it? When I export data to a csv from CFD-post, it only writes one data series, as oppose to the 36 that I need |
Data Read Error ansys CFX | fcabrales | CFX | 3 | April 18, 2011 18:21 |
Can you post a blade data points file example??? | Nicola | Fidelity CFD | 0 | September 21, 2007 11:38 |
Export AreaAve data at each time step in CFX Post | Kumar | CFX | 2 | August 22, 2007 12:32 |
(CFX POST) Rotational Speed | ARJUN | CFX | 9 | July 13, 2006 20:38 |
How to save cell set post data in to a file | Negin | Siemens | 1 | January 27, 2006 03:41 |
