September 9, 2021, 08:42 |
Multiphase Oil Air - Initialization CFX
Rep Power: 14 |
Hello all,
I have a domain where I want to simulate oil-air mixture in CFX I have a wall (rotor) which is rotating at high speed. There are inlets for oil defined with mass flow rate. I want to simulate the effect of oil-air mixture on the rotor - how much the oil-air mixture can cool the rotor surface. I have in my model, only inlets defined for oil. I know there is air present, but no inlet for incoming air. My questions is; 1) Do I patch the domain with Volume Fraction of air = 1 and Volume Fraction of oil = 0 ? 2) Should I use for both Air and Oil the continous phase ? Or should I use for Oil as Dispersed Phase ? Regards, RJ |
September 9, 2021, 10:00 |
Rep Power: 33 |
Is it an oil jet, or oil mist?
You can always initialize each domain, and there is a setting for the volume fraction. Just set it to 1 and 0 respectively.
September 9, 2021, 10:40 |
Henrique Stel
Rep Power: 17 |
Where is the air coming from in the real geometry so that your domain of interest will eventually work with an oil-air mixture? Do you have any information about the expected morphology of this mixture in the real case?
September 9, 2021, 11:17 |
#4 | |
Rep Power: 14 |
The oil-mist spreads over the rotating surface and probably cools it. So should I use air as continous phase and the oil as dispersed phase ? Regards. |
September 9, 2021, 19:17 |
Rep Power: 144 |
Yes, the air is the continuous phase and the oil is the dispersed phase. Have you considered what physical model you are going to use to model this? From what you have described a Eularian inhomogeneous model sounds likely, but you would need to describe it in more detail for us to be sure.
September 11, 2021, 07:19 |
#6 | |
Rep Power: 14 |
I have tried both homogenous and non-homogenous model. With the homogenous model, the simulation runs however I am not sure if it is the right way. When I choose the non-homogenous option, the simulation crashes? Any experience with these two options? any advice would be valuable? |
September 11, 2021, 19:27 |
Rep Power: 144 |
You choose the models to use based on the physics you want to capture, not what appears to run.
If this is a fine oil mist then inhomogeneous is the model to use. Homogeneous is not appropriate. Please upload your Output file from the inhomogeneous run and we can have a look at it. Also please post an image of what you are trying to model, and the results you expect to get.
November 5, 2023, 21:38 |
#8 | |
Duong Tung
Rep Power: 12 |
Hello Juzer, Have you solved this kind of simulation? I am studying this problem also so please let me know if you have already solved it. Thank you, Tung |
November 5, 2023, 22:47 |
#9 |
Rep Power: 144 |
This post is from years ago so it is unlikely he is still around to answer. Better to post a question as your own new thread and we will see if we can help you.
cfx, heat transfer, multiphase, oil, volume fraction |
Multiphase simulation in ANSYS using air and veg oil | raghuramswaroop | Main CFD Forum | 0 | August 25, 2018 04:45 |
Air volume fraction in Multiphase flow in Hydrocyclone | RyanBari | CFX | 3 | August 7, 2017 09:03 |
CFX temperature initialization | jp_ | CFX | 3 | August 28, 2014 10:06 |
CFX Air conditioning Simulation_expression help!!!! Urgen!!! | yin2 | CFX | 6 | March 31, 2009 00:34 |
multiphase flow, CFX or FLUENT? | luis | Main CFD Forum | 6 | October 5, 2006 14:24 |
