Under relaxation
Like Tree6Likes
  • 1 Post By Opaque
  • 3 Post By Gert-Jan
  • 1 Post By Gert-Jan
Old   August 12, 2021, 09:30
Default Under relaxation
Mercurial
Techies is on a distinguished road
Hi guys,
I'm finding under relaxation factor to make my solution converge.
I just have questions: Where is the under relaxation in CFX, how to specify it ? and what are the values that everyone often use ?
Techies is offline   Reply With Quote
Old   August 12, 2021, 09:36
Opaque will become famous soon enough
May I ask why you need under relaxation factors to converge the solution?
The fact they are not obvious is an indication they are not "generally" needed, and likely the software uses a different approach to achieve converged solutions.
Mixing approaches could hide a setup issue, or make things worse in the long term.
Would you mind elaborating on your convergence problems?
aero_head likes this.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Opaque is offline   Reply With Quote
Old   August 12, 2021, 09:43
Mercurial
I'm working with sst model with Reynolds from 5000 to 30000. But at Re 30000, RMS is unstable and results is not yet converge . So i want to modify the under relaxation
Old   August 12, 2021, 10:00
Gert-Jan
Gert-Jan will become famous soon enough
CFX does not use underrelaxation factors. It works using so-called false timesteps. Therefore you should reduce the timestep size which is 1 by default.
karachun, aero_head and Techies like this.
Gert-Jan is offline   Reply With Quote
Old   August 12, 2021, 10:17
Mercurial
Can u tell me where is it ?
Old   August 12, 2021, 10:26
Gert-Jan
In fluent, you can find these under Solver Controls.
CFX isn't very different. In CFX-Pre, it is called Solver Control.
Btw, I don't know which Fluent version you are used to work with, but lately ANSYS incorporated the CFX way of solving into Fluent. There it is called Pseudo Timestepping.
Old   August 12, 2021, 10:55
Mercurial
Sorry but i can't find Pseudo Timestepping Just see Timescale factor
Old   August 12, 2021, 11:07
Gert-Jan
That is what you need to reduce.
So, in CFX it is called Timescale Factor.
In Fluent it is called Time Scale Factor as well, but it is in the menu Pseudo Transient Settings.
BTW, don't use "local timescale factor", like in your picture. Use the default settings and use a timescale factor of 0.25, or 0.5.
Techies likes this.
Old   August 12, 2021, 11:20
Mercurial
thanks for ur hepling me
Old   August 14, 2021, 00:42
Mercurial
Why are my result using timescale factor different from normal result ?
Old   August 15, 2021, 18:36
Gert-Jan
https://www.cfd-online.com/Wiki/Ansy...ated_questions
Techies likes this.
Lets talk about relaxation factor optimization chriss85 OpenFOAM Running, Solving & CFD 35 June 21, 2019 10:54
Long output in terminal. ssa_cfd OpenFOAM Running, Solving & CFD 1 March 18, 2019 06:25
About equation relaxation chriss85 OpenFOAM Running, Solving & CFD 1 May 2, 2017 20:52
Relaxation and convergence sammi Phoenics 0 March 20, 2008 04:32
Question on adjusting relaxation factor CFD Rookie Main CFD Forum 3 January 26, 2004 15:37
