Swirling flow in a diffuser: K-E over SST ?
Like Tree2Likes
  • 1 Post By Felix
  • 1 Post By Glenn Horrocks
Old   February 27, 2007, 10:48
Default Swirling flow in a diffuser: K-E over SST ?
Felix
Hello to you all CFDers,
I am modeling an axisymmetric diffuser with an inlet swirling flow. Experimentaly, the flow did not separate from the wall nor did it present a recirculation zone in the core. So far, the K-E model results I get are much closer to the experimental data than the SST ones (although not perfect) and that gets me a litle confused. In fact, the SST predicts a separation early in the diffuser causing a jet-type flow field and thus cannot predict anything correctly afterwards.
The case I am investigating was studied experimentaly by Clausen and numericaly by Armfield (late 80s/early 90s) and has a total divergence angle of 20 degrees. All the data is available on the Ercoftac database.
I haven't proved mesh independence yet but I took care of using Y+ < 2 for the SST and 25 < Y+ < 40 for the K-E. Has anyone ever simulated this case in SST ? What were the results ? How did you get them ? I'm getting more and more curious about the real predictive ability of the SST turbulence model.
Thanks to all, best regards,
Felix
khaledhmz likes this.
Old   February 27, 2007, 12:34
Default Re: Swirling flow in a diffuser: K-E over SST ?
matej
I did not modelled this case, but I've just spend all day putting together the results comparing k-eps and SST with experiments on swirling combustor and it seems to me, that non of the models is better than the other one. While tangential vel. profiles are closer to the measurements for SST, the size of recirculation zone is to my surprise better predicted by k-eps. not easy to decide.
maybe SAS has the answer....?
matej
Old   February 27, 2007, 18:44
HekLer
Generally the two equation models on their own are not particularily suited to strongly swirling flows.
SST is a blend between k-epsilon and k-omega. If you throw the 25<y+<40 grid at SST it should behave similarly to k-epsilon.
That being said the early separation must be a result of the eddy viscosity prediction being less (flow is not as thick) which is tied to prediction of the local pressure gradient and mean velocity gradients.
One other thing to do is contact the CFX help desk and ask if this case has been run by them. It may have been.
Old   February 27, 2007, 22:03
k-epsilon has well-known deficiencies in modelling swirling flow. SST has some terms in it to account for swirling flows but if you want to model swirling flow with a RANS approach you should really consider the Reynolds stress models.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Swirl diffuser flow lpy2009 FLUENT 2 January 8, 2015 03:20
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 06:44
difference between swirling flow and vortex flow? lcw Main CFD Forum 0 August 22, 2005 10:47
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
