measure the water depth in cylinder
Like Tree1Likes
  • 1 Post By ghorrocks
Old   May 29, 2021, 18:32
Default measure the water depth in cylinder
hamid
hm____reza is on a distinguished road
Hi all
How can I measure the water depth in a cylinder in the two-phase model in the CFX post?
hm____reza is offline   Reply With Quote
Old   May 30, 2021, 03:57
Define "depth". Where the free surface is along a line? Volume of water? Averaged free surface height on some defined plane?
The volume of water is easy - volumeInt(Water phase)@Domain
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   May 31, 2021, 02:23
M
AtoHM is on a distinguished road
Create a surface where the phase volume fraction is 0.5. Assuming your z-coordinate is along the vertical axis, you can then get the average z value at your surface and subtract the bottom z coordinate.
AtoHM is offline   Reply With Quote
Old   June 15, 2021, 14:36
hamid
Thank you for your kind answer; I wanted to do it with an expression, not manually
Old   June 15, 2021, 14:37
hamid
Thank you for your kind answer; I wanted to find where the volume fraction is 0.5 in line,
and do it with an expression
Old   June 15, 2021, 21:16
The average depth of water is easy: volumeInt(Water phase)@domain/area()@Bottom Surface
Is that useful? If not, please define exactly how you define the depth. There are many ways of measuring the depth. Consider a swimming pool - how deep is it? (It depends on how you measure it)
aero_head likes this.
Old   June 16, 2021, 03:43
M
Thats easily implemented in a function and Glenn already spoiled part of it. You can do this!
cfd - post, cfx & air content
Cylinder impact on water using VOF EnriqueP Fluent Multiphase 2 July 2, 2018 04:40
How to calculate water depth? sirpinkyo EnSight 2 December 22, 2016 17:31
[General] The elevation of water around a cylinder abAndad ParaView 0 June 10, 2015 07:44
Reference value for Area and Depth for a circular cylinder in fluent babak.mahjoub FLUENT 0 September 5, 2013 23:55
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 08:10
