Post Processing transient simulation on CFD Post |
Gabriel Rodrigues de Oliveira Anunciação
Rep Power: 0 ![]() |
I'm running a simulation with around 2100 timestep. It's a simple 2D geometry for a flow over a cylinder.
I need to calculate the average Surface Nusselt Number over the cylinder surface for a certain period of time, so I about creating a transient chart and export it so I can have that data for the entire simulated time and then average it for the period of time I need. However, when I try to create that chart, I'd have to specify my data source, which I thought it'd be be the circular surface, which I don't know how to specify and also when specifying my Y-axis value, I can only choose the Surface Nusselt Number, not the average value. Can anyone help me with that? I'm open for some other ideas as well. |
Rep Power: 144 ![]() ![]() ![]() ![]() |
You can do this in CFD-Post, but I find it is not the most flexible program for doing analysis like this so I tend to use specialised plotting packages like python/matplotlib, matlab or even MS Excel if that is all you have
![]() I would generate a monitor point defined as something like areaAve(HTC)@Cylinder, and rerun the simulation. Then you can export the data from the monitor point at every time step in Solver Manager (or the command line), and take the data into your chosen plotting package and plot it there.
average, chart, postprocessing, transient |
Time step independence study for transient CFD simulation | Anna Tian | Main CFD Forum | 50 | October 26, 2021 12:02 |
saving transient data for post processing in tecplot | Aijiazi | Main CFD Forum | 0 | September 9, 2020 08:01 |
Post Processing of LES simulation | likhitha | Visualization & Post-Processing | 1 | August 17, 2020 11:19 |
Transient simulation / plot on CFD Post | Flowin | FLUENT | 0 | June 26, 2020 11:51 |
How to create velocity profile for falling ball in fluent CFD post processing | valr | FLUENT | 2 | June 13, 2018 06:18 |
