May 26, 2021, 06:45 |
Initializing unsteady
Adithya
Rep Power: 5 |
Hi
I am running an unsteady simulation of a GA airplane. The unsteady will be a full model since I want to study the influence of the rear propeller (actuator disk) on the tail. Can I run steady state simulations on a half model and use that to initialize a full model for unsteady sims? Any references I can look at? Thank you |
May 26, 2021, 07:46 |
Rep Power: 144 |
I would have thought that the flow coming off the prop would induce a spiral flow around the aircraft. This flow cannot be modelled with a symmetry plane.
I think you will have to do a full steady state model to get an initial condition.
actuator disk, cfx, unsteady |
Problem with restart in FSI unsteady simulation | david_mocholi | SU2 | 1 | June 24, 2023 07:06 |
Initializing an unsteady solution from previous solution | Mahdi_Kh | FLUENT | 0 | May 31, 2016 09:12 |
Star ccm 9.02 - unsteady flux dissipation correction | fivos | STAR-CCM+ | 4 | April 28, 2014 10:37 |
Error with the unsteady flamelet Model | Christoph_84 | FLUENT | 0 | February 25, 2010 12:06 |
Unsteady flow initializing? | Erica | FLUENT | 4 | March 4, 2005 02:00 |
