GUI Setting & Keyboard shortcut in ICEM CFD10 |
February 10, 2007, 07:03 |
Dear All,
I went through complete tuturial available with ICEM installation. However, I could not find any comment about GUI customization and keyboard short cut. Is there any way to create a keyboard short cut for Standard operations, save, open, close to being with. Thanks, Amod Kumar |
July 7, 2014, 06:11 |
Rep Power: 12 |
You can type? and press Return in ICEM TUI, then you will get this:
----- Currently defined keyboard shortcuts ------ Control-a Merge Surfaces Control-c Create Curve Control-d Delete geometry permanently Control-e Curtain surface Control-f Move facets to new Control-g Split Curve Control-m Copy Geometry Control-p Project curve to surface Control-s Extend split Control-y Redo last undone operation Control-z Undo last operation F10 Save project F11 Emergency reset F12 Save hardcopy F4 Emergency reset F5 Set wireframe offset F6 Set wireframe offset to 0 F7 Increment wireframe offset F8 Decrement wireframe offset Shift-C Create Surface Shift-E Stitch/Match Edges Shift-I Isometric view Shift-P Project Point to surface Shift-R Reverse view Shift-X View in X direction Shift-Y View in Y direction Shift-Z View in Z direction Shift-question Print shortcuts a Concatenate curves b Build diagnostic topology d Delete geometry entities e Extend surface f Faceted tools g Concatenate curves h Home position j Toggle solid display m Move Geometry o Offset Surface p Project Point to curve s Split Curve x Scale to fit z Zoom in |
ICEM keyboard problem in linux | gravis | ANSYS Meshing & Geometry | 4 | February 28, 2020 10:23 |
icem cfd ai environment 11.0, laptop keyboard problem, linux | pertupd | Hardware | 3 | October 3, 2011 09:27 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 22:58 |
ICEM Default Setting Customization | Amod Kumar | CFX | 0 | September 17, 2007 04:57 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 05:41 |
