Error in subroutine cal_WALLDIST
Like Tree1Likes
  • 1 Post By spy_hzdr
Old   May 6, 2021, 11:14
Default Error in subroutine cal_WALLDIST
Pengyu SHI
spy_hzdr is on a distinguished road
Why in CFX drag coefficient cannot be defined as a function of the wall-distance?
Hi there, I am working on Euler-Euler simulation of bubbly flows in vertical pipes. My aim is to test a new drag force model, according to which the drag coefficient would increase when the bubble is approaching the wall.
I first tested the standard drag force model of Ishii-Zuber and the simulation was ok. I then modified the drag coefficient by multiplying the standard drag coefficient by a prefactor. This prefacor is a function of wall distance normalized by the bubble radius (e.g. prefacor = min(10, (1+0.1*LR^-4)) with LR = Liquid.Wall Distance/1 [mm]). The new simulation crashes in the first loop with the report given below. Can anyone give me a hint?
Best regards,
Pengyu
OUTER LOOP ITERATION = 1 CPU SECONDS = 3.218E+00
| Equation | Rate | RMS Res | Max Res | Linear Solution |
| Wallscale-Liquid | 0.00 | 2.6E-04 | 3.1E-04 | 42.4 2.6E-01 ok|
Error in subroutine cal_WALLDIST :
Error calculating WALLDIST_FL2
GETVAR originally called by subroutine cal_CAB_MOM
| Writing crash recovery file |
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| Stopped in routine GV_ERROR |
spy_hzdr is offline   Reply With Quote
Old   May 6, 2021, 12:28
Gert-Jan
Gert-Jan will become famous soon enough
I think the variable "WALLDIST_FL2" is refering to the second fluid. I would therefore try Gas.Wall Distance in stead of Liquid.Wall Distance.
Gert-Jan is offline   Reply With Quote
Old   May 6, 2021, 13:59
Pengyu SHI
thank you for the suggestion. I tried but got the following error:
Error calculating WALLDIST_FL1
| Message: |
Old   May 6, 2021, 19:14
I suspect the Wall Distance variable is only calculated if you are using a model which requires it - which is normally a turbulence model in the SST family. So unless you are using an SST based turbulence model the Wall Distance variable will not exist.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   May 7, 2021, 04:18
Pengyu SHI
thank you Glenn for the kind reply. Indeed, I am using SST. Also, I am pretty sure the Wall Distance variable is available in the setting: I also tried to modify the rest interfacial forces (e.g. lift, virtual mass, turbulent dispersion, wall lubrication) in a similar way as I did for the drag and all these simulations are ok.
So, it seems that one can multiply a function of the wall-distance to any of the interfacial force coefficients except the drag coefficient.
Old   May 7, 2021, 05:38
Are you sure the Wall Distance variable is by phase? I mean you have "Liquid.Wall Distance", but is it just "Wall Distance"? The wall distance is the same as a location for all phases.
Old   May 7, 2021, 11:37
Pengyu SHI
yes. this is for sure, although "Liquid.Wall Distance" is the same as "Gas.Wall Distance".
Old   May 7, 2021, 11:42
Default problem solved
Pengyu SHI
Hey everyone,
the problem disappears when I switch from CFX19.2 to CFX21.1. So, likely it is a bug with CFX19.2. Thank you veryone for your time.
Opaque likes this.
cfx, drag coefficient, wall distance
Calculation Error in USER subroutine Asif17 CFX 3 June 29, 2016 04:45
Compiling User Fortran with CFX 14.0 on Win64 Raijin Thunderkeg CFX 29 March 9, 2016 12:45
Error in subroutine CONVERT_NAME_U2S_INT JDQFD CFX 2 January 21, 2014 10:19
Fortran Subroutine Error sergiorbrett CFX 12 September 3, 2012 08:40
Errorin subroutine appeared when applying cavitation model pitisrisuk CFX 1 July 2, 2012 04:36
