April 12, 2021, 17:23 |
zero-gradient BC at the outlet
phd
Rep Power: 13 |
Hi, there
I’m validating a pipe flow simulation with the experiments. At the exit I need to apply the zero-gradient BC at the outlet to indicate the flow has fully developed: partial-d u/ partial-d x = 0 I saw fluent and openfoam have option to apply zero-gradient BC at the outlet. But in CFX, I didn’t find it. I can only assign the outlet pressure but the outlet pressure value is not shown in the experimental paper. Could you tell me how to apply zero-gradient BC at the outlet? Thank you in advance! |
April 12, 2021, 18:13 |
Rep Power: 144 |
CFX does not have this boundary condition.
If the flow is incompressible then it does not matter - you can use a pressure boundary condition at the outlet and it will set the pressure level (assuming you have not set the pressure anywhere else) and the momentum equation will have zero gradient applied. If the flow is compressible (or material properties are a function of pressure) then things get more complex.
boundary condition |
Volume fraction at outlet not known | Bisht | FLUENT | 8 | September 5, 2017 02:38 |
zero pressure gradient as outlet condition | rsaurabh | FLUENT | 0 | April 13, 2017 18:47 |
Boundary condition confusion. Engine exhaust manifold ventilation. | UPengineer | Main CFD Forum | 1 | July 12, 2016 17:53 |
Zero gradient BC for outlet | paulzhang | SU2 | 0 | April 7, 2016 21:29 |
Zero streamwise gradient at outlet | san.pirate | CFX | 0 | October 14, 2009 18:33 |
