Time averaged WSS varies at different time steps
Like Tree1Likes
  • 1 Post By ghorrocks
Old   March 23, 2021, 21:34
Default Time averaged WSS varies at different time steps
mejahan is on a distinguished road
Dear CFX Experts,
I am trying to calculate the Time averaged WSS on a surface in a transient simulation.
I defined the following expression in CFX post:
areaAve(Wall Shear.Trnavg)@<target surface>
I expect that this would return a number independent from the selected time step, however, it changes when selecting different time steps.
I CFX-Pre, I did not specify the start/end time steps for the transient statistics.
I appreciate your advice in advance.
Thank you,
mejahan is offline   Reply With Quote
Old   March 24, 2021, 00:35
Kira
aero_head is on a distinguished road
Have you seen this thread on the same topic?
Time Averaged Shear Stress
aero_head is offline   Reply With Quote
Old   March 24, 2021, 01:56
Hi Kira,
In the post you referred to, it was suggested to export the values to Excel and calculate the time averaged WSS. However, is seems to be for older CFX versions.
CFX can calculate the time averaged WSS if the transient statistics is activated in CFX-Pre. However, I assume that WSS.trnavg on a surface should not change when different time steps are selected in CFX-Post, since it is supposed to calculate an average value over the entire simulation time.
Any thoughts on this problem?
Old   March 24, 2021, 06:00
Yes, that thread was before the transient statistics capability was available, or at least before I was aware of it
When you calculate areaAve(Wall Shear.Trnavg)@<target surface> for different time steps, doesn't the transient average function return the average of all time steps up to the one you select? So when you change time steps you are adding or removing time steps from the averaging process, so of course it is going to change.
Also: please do not post the same question multiple times. I have deleted the duplicate post. You only need to ask a question once.
aero_head likes this.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   March 24, 2021, 19:19
Thank you Glenn for your response
Therfore, I need to select the final time step to calculate the TrnAvg for the entire simulation.
cfx, transinet simulation, trnavg
LES, Courant Number, Crash, Sudden Alhasan OpenFOAM Running, Solving & CFD 5 November 22, 2019 03:05
Inconsistencies in reading .dat file during run time in new injection model Scram_1 OpenFOAM 0 March 23, 2018 23:29
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 06:28
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 12:08
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
