March 15, 2021, 03:13 |
Yplus value won’t drop below 5
DhyaniBaba
Rep Power: 7 |
I am simulating a steady state flow over a generic turbine nozzle. I started with k-omega model, but my results were fluctuating in grid convergence study. So, I switched to k-epsilon model. Now, I am getting stable results. But no natter how small I keep the first element height, my y plus values won’t go under 5. I have ran multiple simulations with first element offset being a factor of 10 of the largest value.
Can anyone tell why this is happening? Is this a property of k epsilon model? |
March 15, 2021, 04:18 |
Rep Power: 144 |
I don't know what it happening, it depends on the details of what you are doing.
The y+ value of the first element is dependant on the mesh you generated and the flow conditions. So if the flow conditions are the same than are you sure the mesh is generating the right sized elements for the y+ values you intend? Note the k-e turbulence model uses wall functions, and you cannot integrate it to the wall. This means that if you use the k-e turbulence model with y+ values smaller than 11 then you are applying what may be an inappropriate boundary condition.
March 15, 2021, 18:56 |
DhyaniBaba
Rep Power: 7 |
I create my mesh in Turbogrid. I can change the overall mesh size and the first element size independently. My inlet conditions are the same, so I estimate the first element size with the chord based Reynolds no.
CFX uses automatic wall functions where the solver uses a solver yplus that stays around 11 irrespective of the actual y plus values. So, I was assuming that it would not cause a problem. Another interesting fact, with k-omega model, the y plus value doesn't drop below 1.8, no matter how small wall element size I use. So, I am confused if this is the geometry that is causing the problems. or something else? |
March 15, 2021, 19:09 |
Rep Power: 144 |
Your comment is not quite right. The k-e wall functions model the log-layer in the turbulent boundary layer which lies from y+ = ~11 to a much bigger y+. If your mesh actually has a y+ of < 11 then you are modelling it as if it is the log layer, and not the viscous sublayer which is the actual case.
The result of this is that you are not applying a mathematical model which predicts the viscous sublayer accurately for y+<11. But whether this is significant for your simulation or not depends on what you are trying to do and the accuracy you require. You are correct in saying that for many applications this issue does not create a large enough error to be important.
March 15, 2021, 19:12 |
DhyaniBaba
Rep Power: 7 |
My application is with jet cooling on turbine blades. And I need to have a yplus that can capture the jet effects. That is the reason why I was using k-omega model, but it has been giving me stability issues.
cfx, k-epsilon k-omega, y plus ranges |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 03:36 |
yPlus twoPhaseEulerFoam | Andrea_85 | OpenFOAM Post-Processing | 4 | January 11, 2021 06:01 |
OF 4.0 multiregion case calculate yPlus | pbnuclex | OpenFOAM Post-Processing | 6 | July 16, 2020 05:27 |
rhoSimpleFoam yPlus | tmik | OpenFOAM Post-Processing | 1 | September 16, 2018 16:53 |
heat transfer coefficients with "bad" yplus | Andrew | Main CFD Forum | 4 | April 8, 1999 05:43 |
