The ANSYS CFX solver exited with return code 38 |
Pascal Schmitt
Rep Power: 5 ![]() |
Hello everyone,
I am trying to simulate a cooling channel with air being the working fluid in Ansys CFX. The heat is provided by a heat source being installed at a segment of the channel. The purpose of this simulation is the validation of the RANS simulation in a specific context which I don't want to explain further. When I try to run the simulation, it always stops at a certain number of iteration around 80 and tells me "The ANSYS CFX solver exited with return code 38". In the following example, the solver reached the 96th iteration before returning with an error code: ================================================== ====================Sometimes I returns with the same error code, but at least it creates an result file even though I just changed the minImum number of iterations from 50 to 200. I tried to define some material properties as a constant number instead of a function, but nothing worked, it still stops with the same return code. My variables to watch do not converge unfortunatlly which means the simulation results are not useable. These are my criteria: CONVERGENCE CRITERIA:After some research, I coundn't find existing threads about this topic. Has anyone experienced the same problem or does anyone have a clue what caused the problem ?? If I provided too little information about my problem, then please let me know, I am still a CFX beginner. |
M
Rep Power: 12 ![]() |
The error codes are basically useless. The full .out file will be more helpful, if you could attach that.
Whenever I run into something like that and cant find an obvious mistake, I try to run the case again and see if i can get output of the iteration before the one that fails, to see whats going on. |
Pascal Schmitt
Thanks for your quick answer!
Okay, I already looked a little bit at the results in CFX-Pre, if the solver created one, but nothing conspicuous was visable. I will check CFX-Pre more, maybe I overlooked something. I also attached the .out file of the mentioned sover run. |
Gert-Jan
Rep Power: 27 ![]() |
You use polynomial functions for cp and labda. But these are unbounded. That is a bad idea.
I guess that during the iteration process, your temperature becomes much higher or lower than you expect. Then this will result in unexpected (maybe negative???) values for labda and cp. Therefore you should bound them at minimum and maximum side. Something like: cp = max(2000 [J/kg/K]; min(500 [J/kg/K]; cp(T) )) So, you make sure that cp will always have realistic values between 500 and 2000 J/kg/K. Values are just an example...... Remember, in Pre you can evaluate the functions that you define in a graphical way, making sure that in the range of temperatures you will obtain realistic values. |
Pascal Schmitt
Like I said in my describtion above, if I define a constant cp and lamda , the simulation run will still stop with the same return code. So it seems that this cannot cause the problem.
But I will bound them anyway, because you are totally right. Thank you! |
Gert-Jan
If you look in the out file to this section, I see weird things:
+--------------------------------------------------------------------+ | Average Scale Information | +--------------------------------------------------------------------+ Domain Name : Fluid Global Length = 4.6197E+01 Density = 4.7498E-09 Velocity = 4.8997E+04 ..... Domain Name : Solid Heat Source Global Length = 2.6400E+01 Density = 7.8540E-06 ..... Domain Name : Solid Testchannel Density = 7.9600E-06 ..... So your density and velocity scale are weird. Also, your monitoring points are on mm-scale, your length scale is multiple meters. Did you read in millimeters as meters? In other words, there is something really wrong, but impossible to say what. I would make a back up after a few interations and then check the intermediate result in Post |
Pascal Schmitt
You're right that's really weird. Thanks for your help!
But actually i have no idea what causes the solver to use these values, because in CFX-Pre my density is defined properly. The value itself is kinda right, but it is just scaled to a lower power of ten than what I have defined before. Has anyone experienced a similar problem ? |
Rep Power: 33 ![]() |
Check consistency between the units used to import the mesh, and the "Solution Units" selected for the calculation.
#9 |
Gert-Jan
- You use Length Units [mm]. Why not leave it to [m]? I think CFX is a bit confused now.
- I think the constants in your equation need many more digitis. You defined: Air cp 2 = -4e-09[K^-4]*T^4 + 6e-06[K^-3]*T^3 - 0.0025[K^-2]*T^2 + 0.3043[K^-1]*T + 1019.8 So you now take a4=-4e-9[K^-4] I have seen very weird results with so little digits. At least take 4 more digits, or as many as needed to make sure your Cp does not vary anymore. Bottomline: I would start over again with constant values and leave everything at SI. Then modify one thing a time: restart with modified cp. Restart again with modified labda, etc, etc. |
#10 |
Pascal Schmitt
So I did the setup again with SI and also defined the boundary for my polynomial functions properly. These improvements made my results better, but actually the problem was not really caused by these factors.
My CFX-files were located in a cloud storage space of my institution, so I thought maybe that was causing the problem because of a possible crashing of the cloud. So I located it on the local storage space and it worked! I am sorry for not trying this earlier! Thanks guys. |
ansys 12, cfx, return code 38 |
CFX Solver Manager Error Code 1 | Peta247 | CFX | 3 | June 4, 2016 11:00 |
The ANSYS CFX solver exited with return code 1. No results file has been created | moodkiller | CFX | 7 | May 23, 2016 02:16 |
2-way FSI in Ansys CFX 15 | LucasGasparino | CFX | 3 | August 6, 2015 03:17 |
error about fsi in CFX and ANSYS | WANGFIRE | CFX | 1 | April 21, 2015 01:48 |
ansys solver terminated with returne code -1 | raj.091603.bme | CFX | 1 | February 13, 2014 10:52 |
