March 9, 2021, 16:41 |
Modeling Internal Fan
Thamer Hussein
Rep Power: 11 |
I have a simple non-ventilated enclosure where inside this closed box (the fluid domain) there is fan which is used to circulate the air to cool an object generating heat. But since the fan is pulling the air from inside this box it doesn’t make sense that I define the temperature of the inlet & opening of the fan in the boundary condition since that temperature is dependent on the solution (air temperature inside the enclosure).
I was wondering if there is a tutorial available that covers solution dependent expressions for fan cooling simulation. Or a way of coupling the inlet temperature to the air temperature from the solution. Here’s a brief description of my model:
Thanks, Thamer |
March 9, 2021, 18:04 |
Rep Power: 144 |
You are not modelling this a good way. The best way to model the fan is to use a momentum source term. That way the heat is automatically taken care of, and all you do is use the source term to apply the amount of momentum to the fluid to represent the fan.
March 9, 2021, 18:16 |
Thamer Hussein
Rep Power: 11 |
Ah, I see. I will try what you suggested. Thanks for replying ghorrocks.
March 9, 2021, 19:02 |
Thamer Hussein
Rep Power: 11 |
For anyone who is interested in learning how to model a fan using momentum source term and fan curve I found this video very helpful.
https://www.youtube.com/watch?v=Q-mMbt_3CCc |
March 9, 2021, 23:33 |
#5 | |
Kira
Rep Power: 9 |
Thanks for this addition! |
ansys 19.2, cfx, closed system, fan, internal fan |
Modeling a Fan by the Multiple reference frame (MRF) method in CFX. | saisanthoshm88 | CFX | 11 | February 17, 2021 12:30 |
Modeling Centrifugal fan (blower)! Need Help! | namshaheb | FloEFD, FloWorks & FloTHERM | 2 | December 30, 2020 11:54 |
Ducted fan modeling | mehdi_naderzadeh82 | FLUENT | 0 | January 30, 2013 15:24 |
General CFD Modeling of Fan | bravikanth | Main CFD Forum | 0 | February 18, 2011 04:41 |
flow simulation across a small fan | jane luo | Main CFD Forum | 15 | April 12, 2004 18:49 |
