March 9, 2021, 07:25 |
Getting Variables with USER_GETVAR
Rep Power: 5 |
Hi everyone,
i tried to get the temperature variable via a User CEL Function by using USER_GETVAR. However, when I call the function it doesn't return anything, even the CRESLT variable that should tell if the function call was successful is empty. Then i simplified the routine and tried to get the pressure variable (mabye this function can't get the temperature variable?) but the same error accured. The Code is down below. How do i use this function properly? Is there a bug? If so, is there a workaround? #include "cfx5ext.h" dllexport(adt) SUBROUTINE ADT ( & NLOC,NRET,NARG,RET,ARGS, & CRESLT, & CZ,DZ,IZ,LZ,RZ) #include "MMS.h" #include "stack_point.h" INTEGER NLOC, NRET, NARG CHARACTER*(*) CRESLT REAL RET(NLOC,NRET), ARGS(NLOC,NARG) INTEGER IZ(*) CHARACTER CZ(*)*(1) DOUBLE PRECISION DZ(*) LOGICAL LZ(*) REAL RZ(*) __stack_point__ pT CRESLT = 'GOOD' CALL SET_A_0 (RET, NLOC*NRET ) CALL MESAGE ('WRITE', 'WORKS UNTIL SET_A0') CALL USER_GETVAR ('Steelliq.pressure',CRESLT, & pT,CZ,DZ,IZ,LZ,RZ) IF (CRESLT .NE. 'GOOD') THEN CALL MESAGE ('WRITE', 'GET_VAR NOT GOOD') ENDIF CALL MESAGE ('WRITE', CRESLT) CALL USER_SOURCE_SUB (RET(1,1),ARGS(1,1)) END SUBROUTINE USER_SOURCE_SUB (OUTP, INP) REAL OUTP, INP OUTP = 1000.0 CALL MESAGE ('WRITE', 'WORKS UNTIL USER_SOUCE') END Last edited by Aristid; March 9, 2021 at 09:14. |
March 9, 2021, 08:41 |
Rep Power: 33 |
If I recall correctly, you can use
'Steelliq.Pressure' or 'Steelliq.p' but definitely NOT 'Steelliq.pressure' What surprises me is that you are not getting CRESLT = 'NAME' as documented.
March 9, 2021, 09:52 |
Rep Power: 5 |
Thank you very much for the quick reply!
I now corrected it to 'Steelliq.Pressure', and i also tried 'Steelliq.p', but still the same error accurs (solver crashes and message "solvermanager.exe stopped working" appears). Before that i also tried to get Variables via creating Additional variables (someone suggested this in a master thesis online to avoid this "bug"), but the call to USER_GETVAR fails every time and CRESLT is empty. Have you used USER_GETVAR successfully? Are there alternatives to using USER_GETVAR? I've been stuck on this problem for over a week now and suspected this might be a bug. |
March 10, 2021, 21:04 |
Rep Power: 33 |
Have you run the tutorial or documentation example using user_getvar?
Would you mind posting the basics of your usage of user_getvar?
March 15, 2021, 13:04 |
Rep Power: 5 |
Thank you very much! I have now run "User CEL Example 2" (AdVarSource), and it's running fine.
It looks like the error i experienced is caused by the time the Call to the User CEL Function is made. Before i always tried to check the return Value of the User CEL Function via Monitor Objects but never actually used it. Mabye if i use it somewhere the error will disappear. My Goal is to find the Y-Coordinate of the position where Temperature has a certain Value (f.e. 2000K). My Usage of user_getvar would be to obtain the temperature field in the entire domain (or mabye only on one surface, i don't know yet). By usind user_get_meshdata i would obtain vertex coordinates. Then i would find the index of the temperature value closest to 2000K and hope that the Y-Coordinate-Array has the same indexing as the Temperature Array. |
March 15, 2021, 17:26 |
Rep Power: 33 |
Great!!
You are aware your goal is not a 1->1 match, there can be multiple locations for a given value of Temperature. Not even sorting the arrays you are dealing with will guarantee you a unique solution, or even a repeatable solution, i.e. the same location between calls even if the temperature at the specific location remains constant. Let us know how we can help
cel, fortran, get variable, user_getvar |
[swak4Foam] How to define boundary condition variables by using previosly defined variables? | pawlo | OpenFOAM Community Contributions | 8 | September 13, 2020 12:37 |
Optimal tolerance and variables scaling settings | 4513645ygq | Main CFD Forum | 0 | July 28, 2020 09:56 |
SU2 violates the lower bound of the FFD design variables | cfdjetman | SU2 | 4 | October 2, 2019 17:15 |
Some variables not loading in Tecplot | nick.l.thomas | Tecplot | 1 | October 25, 2018 18:48 |
PHI file structure | Eugene | Phoenics | 9 | November 2, 2001 23:00 |
