Problem with Momentum Imbalance
Like Tree5Likes
  • 1 Post By Gert-Jan
  • 2 Post By Gert-Jan
  • 2 Post By ghorrocks
Old   February 15, 2021, 02:20
Exclamation Problem with Momentum Imbalance
JD
Nerdybat is on a distinguished road
I am a beginner in both CFD and CFX. I am trying to run a wind tunnel case (flow over an airfoil) with the following BC's:
Inlet - Total Pressure, Total Temperature
Outlet - Avg Static Pressure
I am using air ideal gas as the material
While most similar runs with the same BC's have converged, this particular case has a problem. the H-energy and P-mass imbalances do reduce over time(but not below a particular value say 0.05)
But then the W-Momentum imbalance increases and keeps increasing causing other imbalances to increase too and my velocity and static pressure(I've placed monitors) at inlet oscillate continuously because of this. I do not know what the problem is and I would appreciate it a lot if someone helped me out here.
Please reply soon as I am in a bit of a hurry. Thanks
Nerdybat is offline   Reply With Quote
Old   February 15, 2021, 03:53
Gert-Jan
Gert-Jan will become famous soon enough
Sounds like you have found a transient solution. Then don't try to solve it in steady state, but using a transient setup. That won't give you a single value so you need to determine transient average values.
aero_head likes this.
Gert-Jan is offline   Reply With Quote
Old   February 15, 2021, 04:19
JD
Hi Gert-Jan,
Thank you for replying.
What if I intend the problem to be a steady state one? How do I find out where this transient nature is coming from and how do I eliminate it?
Old   February 15, 2021, 04:26
Gert-Jan
During steady state, you can make backups at multiple iterations. In Post you can analyse these to find out what the source is.
It the solution has a transient nature, then mostly there is not much you can do. Sometimes it is possible to increase or decrease the Autotime Scale Factor so that the solver doesn't find the instabilities. Just give it a try.
aero_head and Nerdybat like this.
Old   February 15, 2021, 05:13
There are a few things you should try before you do a transient simulation. The FAQ describes a few things to look at: https://www.cfd-online.com/Wiki/Ansy...gence_criteria
But if it ends up that the simulation is transient then you have to forget about a steady solution because it does not exist.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   February 15, 2021, 07:45
JD
Hi Gert-Jan and Ghorrocks,
Thank you for providing clarity through your replies.
#cfx, #convergence, #imbalance
Table bounds warnings at: END OF TIME STEP CFXer CFX 4 July 17, 2020 00:44
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
Mass flow rate imbalance problem frossi CFX 7 June 7, 2017 21:30
Codding problem for solving momentum equation with periodic magnetic field Aniket Roy Main CFD Forum 0 June 4, 2016 04:21
Simulation of Axial Fan Flow using A Momentum Source Subdomain Liam CFX 28 July 16, 2013 09:24
