December 1, 2006, 09:47 |
CFX - wall heat flux
I 've a question about sign convention in CFX. I made a simulation of steady state heat transfer of an insulated box, with internal T_in= 293 K, and outer of T= 213 K. I've to estimate the optimal thickness of insulating layer, so I created a boundary condition on the internal walls of heat transfer with heat source (energy). I've plotted the wall heat flux on a line across the layer, and noticed that heat flux varies with a peak in a range going from negative to positive values, whereas I expected that it decreases linearly, and in the best case it goes from 0 to negative flux equal to energy input source. Can you explain why this and what does it mean a negative heat flux? Thank you. Eng. Igor Di Varano
December 4, 2006, 13:54 |
Re: CFX - wall heat flux
Fluxes into the computational domain are positive, out are negative. A negative wall heat flux means heat is going into the wall, out of the fluid domain.
-Robin |
December 4, 2006, 17:14 |
Thank you very much, I've found some information on help soon after my previous e-mail. Now there 's another point. I've plotted the wall heat flux through the thickness, but I have only a few points and I've been requested to enhance the number of points in the layer. I've tried to fit the mesh, but without success, as I have always the same points(7). I 've read on the handbook that wall heat flux is sensitive in proximity of wall surfaces, and in a lesser way within the wall. Is it true or with more elements I can expect the desired result? Thanks a lot. Igor
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
CFX Heat Transfer | RJamison | CFX | 0 | July 24, 2008 13:11 |
Wall Heat Flux Boundaries conditions | Abigail | FLUENT | 2 | July 24, 2007 10:34 |
wall heat flux between two fluid zone!!! | Asghari | FLUENT | 2 | August 25, 2006 11:11 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 06:12 |
