January 11, 2021, 14:38 |
ERROR#001100279 GGI boundary error
Evan
Rep Power: 6 |
Hello, I'm currently working on a pump design and I'm running into an issue with two stationary domains (which I can best describe as two 90 degree bends) that are connected to one another. I run the case and the following error pops up.
+--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Both sides of GGI rotationally periodic boundary condition "Chann- | | el Bend 1 to Channel Bend 2" have the same axial or radial positi- | | on. Possible solutions include: (a) check that the condition is s- | | pecified properly; (b) check that the rotation axis for the perio- | | dic condition is set properly; (c) decrease the value of the expe- | | rt parameter "ggi periodic axial radial -ErrMsg buffer overflow- | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine SRF_CORRECT_44 | | | | | | | | | | | +--------------------------------------------------------------------+ Here are some of my setup parameters for this Channel 1 to Channel 2 -The outlet of channel 1 is interfaced to the inlet of channel 2 with a rotational periodicity. |
January 11, 2021, 18:28 |
Rep Power: 144 |
The error message seems to be quite clear - you have set your GGI to be rotationally periodic but the two faces are on top of each other. It sounds like you just want a normal (not periodic) GGI interface to simply connect two mesh regions.
cfx |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 10:00 |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 12:39 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 19:00 |
Errors in UDF | shashank312 | Fluent UDF and Scheme Programming | 6 | May 30, 2013 21:30 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 21:50 |
