Restart CFX simulation in batch mode using ccl |
December 25, 2020, 08:48 |
#1 | ||
Rep Power: 5 |
Hi everyone,
I am running RANS-simulations in CFX 2020R2. I did the setup of the simulation in CFX-Pre and created a .def-file from that: (RANS.def) which I then moved to the storage space on the cluster where I am working. I use an .sh-script file (runCFX_1.sh) to execute the simulation in batch mode on the cluster. Since my settings in CFX-Pre for the convergence criteria (RMS with 1E-4) and the max. iterations of 1000 lead to unsatisfying results, I would like to restart the simulation from the latest iteration which is 1000 and go further up to 2000 iterations. During the first run, the files "RANS_001.res", "RANS_001.out" and the folder "RANS_001/" containing the files "900_full.bak", "reread" and "trn" were created. I've read in some forums that you can use "-inject-commands" in the .sh-script in order to change parts of the settings in the batch mode. Therefore, I adjusted my runCFX_1.sh script and I created the file "newccl" that includes the code for setting the max. iterations up to 2000 and alterning the convergence criteria. Apart from that, I want to activate "double precision" from now on and so I used the command "-double" with the "cfx5solve"-command in my .sh-script. When I execute the script, it seems to run properly but when I have a look into the newly created "RANS_002.out"-file I can see that double precision is activated while the settings to be changed using the "-inject-commands" function remain unaltered. What do the files "runCFX_1.sh" and "newccl" have to look like to make it work? Thanks for your help! Here you find the codes: runCFX_1.sh Quote:
December 26, 2020, 06:29 |
Rep Power: 144 |
I am not familiar with the command line argument "-continue-from-file". I have never used it. That does not mean it does not work, it just means I have no knowledge of it.
I use the "-initial" argument to set an initial condition for a cfx5solve run. Works for me. If you want to change the CCL before you start then do a "cfx5cmds -write -def DefinitionFile.def -text CCLFile.ccl" before you do the cfx5cmds. There are lots of other ways to do it but this is the way I do it and it works for me.
December 29, 2020, 16:37 |
Rep Power: 5 |
Thanks a lot!
It worked with the command line you supposed (cfx5cmds -write -def DefinitionFile.def -text CCLFile.ccl). The only thing I had to change in addition was to put the entire source code from CFX-Pre into my new "newccl"-file and not only the part containing the settings that I wanted to change. |
Monitoring in batch mode | jmjohansen | ANSYS | 0 | July 1, 2015 13:48 |
restart for batch mode | Lawrence | STAR-CD | 2 | April 11, 2010 19:05 |
Saving of monitor points in batch mode. | Martijn | CFX | 3 | December 10, 2008 11:36 |
Prosurf in batch mode | Dhruv | Siemens | 1 | September 19, 2005 19:02 |
Batch mode | swapnil | CFX | 5 | November 23, 2002 10:38 |
