Calculating fluid recirculation at an outlet in transient analysis
Like Tree2Likes
  • 1 Post By AtoHM
  • 1 Post By AtoHM
Old   November 4, 2020, 11:21
Default Calculating fluid recirculation at an outlet in transient analysis
Charlie Heaton
HeatK is on a distinguished road
I'm currently modelling a pipe, which has a sinusoidal input velocity and a 0Pa outlet. In the pipe, there is inserted a two way tube which has both an inlet and outlet at its tip.
Both the pipe and tube use the same fluid. The fluid input from both the pipe and tube mix together inside the pipe, before some exits through the pipe, and the rest exits through the tube.
The pipe and tube are both set up as one domain.
I want to be able to determine what percentage of the fluid exiting through the tube's outlet has also come from its inlet.
I have looked at using particle tracking, using tutorial 29 however this doesn't seem to be quite the right application for that. I may of course have missed something.
If anyone could be of any help, it would be greatly appreciated, thanks
HeatK is offline   Reply With Quote
Old   November 4, 2020, 13:07
M
AtoHM is on a distinguished road
You can create a new scalar variable (passive scalar) for each inlet and insert it with the flow. Then you can monitor how much of it leaves at the respective outlet. You need to add it in the domain settings and specify the transport equation to be solved.
HeatK likes this.
AtoHM is offline   Reply With Quote
Old   November 4, 2020, 13:17
Charlie Heaton
How do i go about creating a passive scalar? or is there a tutorial which details this? Been looking through and can't see anything
Old   November 4, 2020, 15:33
M
I have no time to look up all the steps right now, but I found this, which seems to describe the steps quite well:
Tracer Analysis in CFX
HeatK likes this.
thermal stress analysis with fluid? sheaker FLUENT 0 April 20, 2018 17:32
Error in Two phase (condensation) modeling adilsyyed CFX 15 June 24, 2015 20:42
Locating and observing a transient fluid phenomena Chander CFX 2 September 25, 2011 19:49
My Revised "Time Vs Energy" Article For Review Abhi Main CFD Forum 2 July 9, 2002 10:08
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
