changing model constants in k-e turbulence model
Like Tree1Likes
  • 1 Post By opaque
Old   October 2, 2006, 17:20
Default changing model constants in k-e turbulence model
Sunil
Hi, I would like to know if there is a way to change the Turbulent Prandtl number in CFX when I am using k-e model. This is the Pr_T ( = 1) and Pr_E (= 1.3) in the model equations. There is an option to change ce1 (1.44) and ce2 (1.92), but I cannot find one for the other constants.
Thanks
Old   October 2, 2006, 18:46
Default Re: changing model constants in k-e turbulence mod
opaque
Dear Sunil,
Did you check under TURBULENCE MODEL/Advanced Control/K COEFFCIENTS/TURBULENT FLUX CLOSURE?
Good luck, Opaque
rockzh likes this.
Old   October 3, 2006, 11:55
Sunil
Thanks for the reply. I did check that and I think it is not the same as what I am looking for. flux closure has option to change the turbulent Schmidt number which I believe is not the same as turbulent Prandtl number
Old   October 3, 2006, 13:12
opaque
Dear Sunil,
It is just a matter of semantics..Prandtl and Schmidt numbers naming is used both ways in the turbulence community..
My personal view is that Prandtl naming is only for heat transfer. Schmidt was meant for mass transfer; however, it is the name for generalized ratio between momemtum transfer/<your physics transfer>
That is the correct parameter.. Be aware that the default value shown in the GUI is not correct.
Good luck, Opaque..
Turbulence postprocessing Mohsin FLUENT 2 October 3, 2016 15:18
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 10:52
Fan heater model: what turbulence source to use? andy20 Main CFD Forum 0 March 2, 2008 13:46
Sinclair Model + secondary turbulence Yi FLUENT 0 October 26, 2001 14:37
